electric fuel pump
Old Jan 14, 2010 | 11:46 AM
  #61
starmilt's Avatar
starmilt
dyoung14 curious these rigs are they streetable, and what you are wanting to build, are you planning to keep it a driver or a full blown sled rig or race rig it seems to me that the numbers that they are putting out they will be useless for day to day use.
Old Jan 14, 2010 | 02:57 PM
  #62
Marianna2003's Avatar
Marianna2003
Originally Posted by starmilt
Now I'm lost how would you mount it back to back with the existing filter and keep your pump as close to the tank as possible.
I have only used an electric pump on one of thee motors but in 12 years and 400,000 miles it was only replaced once. NO extra filter.
I'm having trouble copying my pic to the forum.
Old Jan 14, 2010 | 03:10 PM
  #63
starmilt's Avatar
starmilt
If you guys dyoung14 are set on a good electric pump check out the fuel preporater or fass system (same thing just a family squabble). I can't vouch for the ford application but can for the cummins dodge as well as big cam and n14 and cat engines.
Old Jan 14, 2010 | 05:33 PM
  #64
dyoung14's Avatar
dyoung14
Originally Posted by nappy nate
Dyoung14, thanks or clearing that up for me and good luck hopefully you are successful in building the monster of your dreams from your 6.9..Have you had it on a dyno yet?? What kind of valve springs and rockers are you leaning toward??
I remember seeing something about a 70's ford with an IDI and 1000hp at a drag strip, was from an old HOT-ROD mag or something......Am I talking out my *** here Or do any of you guys know of the white ford p/u with cloud of diesel smoke erupting from the stack that I speak of......I couldn't find the link.
The way my memory serves me It was probably a volvo with 100hp during the 90's.
nate
i have not decided what of anything im going to use right now, all im doing right now is finding out whats going to break when you spin them this high, so far nothing! and i found out high timing makes great power, but headgaskets dont like it at all, cause im almost certain i blew one last night
Old Jan 14, 2010 | 05:35 PM
  #65
dyoung14's Avatar
dyoung14
im not looking for 1000+ hp
Im looking to pass the 300hp mark that it seems no one can pass for some reasin, im going to try to build a fairly streetable engine, so twin compound turbos is probly going to be that option for fast spool along with high boost up top, i would like to see 450 500 hp but i may be over shooting
Old Jan 14, 2010 | 07:04 PM
  #66
FORDF250HDXLT's Avatar
FORDF250HDXLT
it would probably just be less expressive and easier to start with someone besides the IDI for the 500+hp mark dyoung.
Old Jan 14, 2010 | 07:25 PM
  #67
dyoung14's Avatar
dyoung14
yes i know you can get suck large amounts of power with a cumapart, but eveyone has one its old i dont like being the same as everyone, i like to be different and have things no one else has
Old Jan 16, 2010 | 03:57 AM
  #68
Dave Sponaugle's Avatar
Dave Sponaugle
I have a picture for you.
That used to be a street driven Power Stroke, running somewhere around 105 pounds of boost when it blew.
Old Jan 16, 2010 | 03:26 PM
  #69
dyoungen's Avatar
dyoungen
Ouch, I bet that hurt!!
Old Jan 16, 2010 | 11:43 PM
  #70
87crewdually's Avatar
87crewdually
This by far is probably one of the best pics I've seen you post. Bigtime WoW factor.
Old Jan 16, 2010 | 11:47 PM
  #71
starmilt's Avatar
starmilt
A little nickel rod and she'll be back on the road in the morning. You can't kill a ford.
Old Jan 16, 2010 | 11:50 PM
  #72
87crewdually
There's alot of things I'd repair while some would throw it away, this is deffinitely trash!
Old Jan 16, 2010 | 11:57 PM
  #73
FORDF250HDXLT
hot damn!
could you imagine being in that rig when she blew apart!
the guy must of .......... himself! hahaha.
Old Jan 17, 2010 | 12:29 AM
  #74
starmilt's Avatar
starmilt
A friend had a flywheel , clutch and pressure come through the floorboard, it started chewing on his ankle and finished above his knee. it wasn't pretty.
Old Jan 17, 2010 | 07:53 AM
  #75
Dave Sponaugle
That truck belongs to the son of the owner of BTS transmissions.
As the story goes, BTS transmissions are E4OD transmissions he builds, and then dares you to break them.
That was a 96 Stroke engine, 105 pounds of boost making north of 900 HP on fuel only.
Transmission was fine, engine not so fine.
Since the transmission was bolted to the engine, I have to wonder how the case survived when the engine block self destructed.
Maybe the transmission internals were OK and the case was not so fine.
Also noted up in the Stroke forum, the crank and connecting rods look just fine.
Star also brings up an excellent point about high RPM's, consider where your feet are in relation to where the clutch is as you over rev the engine.
Given the weight of the flywheel, clutch and pressure plate, the aluminum bell housing and floor boards won't even slow them down if it lets loose.
