power steering pump pulley
Old Jan 9, 2010 | 09:54 PM
skyjacker10's Avatar
skyjacker10
How do you remove the pulley on a 97 f350 we tried for an hour and a half this evenin. Neither air tools or a breaker bar would do the trick
Old Jan 9, 2010 | 10:13 PM
live2wheel's Avatar
live2wheel
there is a kit that has a special clamp and washer with a screw that fits on the front of the pulley to remove it and press it on. they usually have them at the auto parts store that you can use for free.
Old Jan 9, 2010 | 10:27 PM
matts156's Avatar
matts156
If I'm not mistaken, the puller you need will look something like this.
Old Jan 9, 2010 | 11:12 PM
mueckster's Avatar
mueckster
Mine look like this:
Ford used 2 different size lips on the pulley flange for removal. The smaller, "C" shaped one fits the Superduties. The one with the stud and thrust bearing is the installer.
Old Jan 9, 2010 | 11:21 PM
mueckster's Avatar
mueckster
I had one like that for Chrysler alternator pulleys. I ground down the hooks to fit the pulley on the OBS diesel vacuum pump.
Old Jan 10, 2010 | 09:24 AM
BadDogPSD's Avatar
BadDogPSD
Attachment 20130
Yep, these are the correct ones for Fords. Need one for the removal, and a different one for the install.
Old Jan 10, 2010 | 09:30 AM
95_Dually's Avatar
95_Dually
Most auto parts stores will either loan them or rent them to ya.
Old Jan 10, 2010 | 10:35 AM
matts156's Avatar
matts156
I think the one I posted a picture of will help you get the pulley off, but not back on. The ones Mueckster posted would be the ones you need to do both.
Old Jan 10, 2010 | 10:04 PM
tbone heller's Avatar
tbone heller
This is to remove the distributor gear on a gas burner when replacing the stator.
Old Jan 10, 2010 | 10:25 PM
triskadek's Avatar
triskadek
I used the first posted pic to pull the gear off my vacuum pump pulley and the threaded presser to put the pulley on the new pump. I've heard the vacuum pump may be the same size as the power steering pump, but I haven't confirmed.
Adam Wyer
Modular V8 (4.6L, 5.4L)
Jul 16, 2017 12:37 PM
dthut
Mar 18, 2017 01:00 PM
mxer0022
Sep 13, 2016 09:58 PM
Kingkoopa
Nov 8, 2013 03:49 PM
SuperSabre
Jan 15, 2011 07:47 PM
