Damnit! Thanks. Why can't they design stuff with the average person in mind. Would it be so hard to put a keyway in the shaft. Ito already got threads for a bolt.
So how do the high pressure line plastic gasket and o-ring go on? Actually just the plastic one, the o-ring is self explanatory. The plastic gasket was too small to go over the line fitting and too big to go in the pump side.
I put it on the same way I put o-rings on, a 90* pick and work it around and up at the same time. I put 3 pumps on in 2 weeks, it worked every time.
