Battery note
Old Jan 8, 2010 | 06:25 PM
onelionhunter's Avatar
onelionhunter
Battery note
All,
Something interesting on battery testing I ran into this afternoon. Friends 2001 was very weak rolling over and needing jumped the last week or so when i stopped by his house. So I took out the trusty digital volt meter, and put it to the battery terminals on the drivers side first, 14.4 volts. Put it on the passenger side, 12.3 volts. Thinking, ok, this is wierd.....
So, I went to pass side again, put the meter to just the battery posts, same thing, 12.3 volts. Put it on the cables on pass side next, and it read 14.4. So, that told me instantly, bad connection. Took them apart, cleaned, nolaxed, and now they read 14.4 at the battery (did the driver side with nolax as well)
Just a note on trouble shooting bad connections in the future, I thought it quite interesting anyhow....
Old Jan 8, 2010 | 06:45 PM
togobefastguy's Avatar
togobefastguy
thanks for the advice
Old Jan 8, 2010 | 06:47 PM
RV_Tech's Avatar
RV_Tech
That is a nice thing to remember and you explained it well.
Thanks,
Steve
Old Jan 8, 2010 | 09:42 PM
Excursion4X4's Avatar
Excursion4X4
Had the same problem with my Ex about 2 months ago. Thought it was operator error tho, so I didn't say anything.........
Old Jan 8, 2010 | 09:55 PM
8tsixt's Avatar
8tsixt
I am going to have to replace the cables on mine soon due to the positive cable is beyond the point of cleaning.
Old Jan 8, 2010 | 10:34 PM
WA.Ranger's Avatar
WA.Ranger
Great tip Tom. Tried to rep you, but.................
I will be building my own cable shortly and will be using some extra 2/0 welding cable I have extra and these solder on battery terminals from NAPA. I used these terminals on my Dad's Cummins and they are solid copper and very easy to install.
Store Locator | NAPA Online
Old Jan 8, 2010 | 10:39 PM
8tsixt's Avatar
8tsixt
Please take some pics of your work to possibly create a copy of yours, If you dont mind.
Old Jan 8, 2010 | 10:45 PM
RV_Tech's Avatar
RV_Tech
I used to use solder on, but found it faster and works as well to use hammer-ons. The vice to hold the cable end doesn't cost much and one blow of a ball peen is all it takes. If you need to make more than a couple of cables, it is worth trying. The hammer-ons are also solid copper.
Steve
Old Jan 8, 2010 | 10:46 PM
WA.Ranger's Avatar
WA.Ranger
No problem Carlos, will do. Probably a couple of weeks out from starting them though.
Old Jan 9, 2010 | 08:19 AM
farmdad's Avatar
farmdad
Steve
What brand did you use? Guess I haven't heard of hammer-on cable ends. Sounds like something I would be interested in.
Tom, thanks for the thread. Just goes to show that nothing should be overlooked when tracing a problem. And it was an easy fix.
Old Jan 9, 2010 | 08:27 AM
RV_Tech's Avatar
RV_Tech
Morning,
One thing I should have mentioned is they only are available for a threaded post. If you are using a post you have to clamp to, they will not work, although you can get ends that wrench on or pinch on (not the emergency clamps most folks buy at the auto parts stores). You can get the material you need for hammer-ons at Battery Cable and Power Distribution. I like them because they save me a good deal of time and I have to make cables of all sizes routinely. You can also find hammer-ons at Lowes in the specialty parts section with the nuts and bolts. You will not find a full selection of sizes, however.
Good luck,
Steve
Old Jan 9, 2010 | 09:47 AM
Nick 99's Avatar
Nick 99
If you are going to use the compression connectors, make sure the cable and connector are shiny clean inside and out. Next make sure to use a product like Noalox inside of the barrel of the connector before you insert the cable, to prevent corrosion by sealing out the oxidation. Now you are ready to crimp the cable into the barrel of the connector.
Nick
Old Jan 9, 2010 | 11:45 AM
sflem849's Avatar
sflem849
Not to knock the compression/hammer-ons, but I think solder is necessary in the connection. As Nick pointed out some form of corrosion inhibitor is also necessary.
When I was in the marine industry we would use the compression ends and then solder them to make a better connection. We would also place shrink wrap tubing over the end to seal the connection. Don't forget to do this before you beat your end on!!! I never forgot...right In addition, don't have the shrink wrap too close to the heat or you will shrink it on way up the wire. Copper is a great conduction of electricity AND heat.
To solder, place the battery terminal end in the vice. Some say you should heat just hte connector and put the solder and others say put the wire in the connector and then the solder. I am a wire in the connector and then heat and solder. I have seen solder just kind of pool around the wires when you put it in the molten puddle so I prefer heating the whole deal. Plus you don't waste as much solder.
We would get all of our connections at NAPA. They had everything we needed.
Old Jan 10, 2010 | 08:23 PM
onelionhunter
thanks all
Thanks for the comments, just wanted to add to the seeming never ending battery issues we all seem to have to diagnose. Hadn't seen any yet that kind of isolated the bad connection so easily, at least if it is at the terminal, hence the post.
