NEED HELP INSALLING ABS HEADLINER
Old Jan 7, 2010 | 07:05 PM
bobs1948f1's Avatar
bobs1948f1
Just received headliner and other interior panels from Roddoors and they look good but not impressed with the fit especially the two front corners above the windshield. Also I assume the headliner and other panels are held in place with the dualloc tape which presents another problem because the tape itself is thicker then the depth of the lip around the door where the panels rest. Any suggestions, pictures or information would be greatly appreciated.
Thanks Bob
Old Jan 7, 2010 | 08:30 PM
Old F1's Avatar
Old F1
Those are my door panels that you got, it’s a long story, I will tell you about it someday.
There was another thread (maybe) (# 3) about using clips but can’t find it and desert is ready so you will have to look, check backwards from posts by the guy saying thanks / sent e mail, the two post here talk about Rod Doors panels and some solutions.
see post # 12;
https://www.ford-trucks.com/forums/8...t-sources.html
https://www.ford-trucks.com/forums/8...nel-clips.html
Old Jan 7, 2010 | 08:47 PM
51truck's Avatar
51truck
I did not use the clips from Rod Doors on mine. Went to the hardware store and some small black automotive trim screws. Its dosent take much to hold in place, I drove mine a couple weeks befor I fastened it to truck. My front corners dont fit perfect but take your time and work with it and you can get them pretty close.
Old Jan 8, 2010 | 09:22 AM
divermo's Avatar
divermo
Texan
Do you have contact info for Rod Door? Website/phone# etc.
Thanks, Mark
Old Jan 8, 2010 | 06:55 PM
bobs1948f1's Avatar
bobs1948f1
Thanks, Mark
Hi Mark, they are still producing these parts and I bought them through Classic Haulers (877-252-1948) contact: Candi.
Good luck, Bob
Old Jan 11, 2010 | 01:11 PM
peecubed's Avatar
peecubed
I used the rod doors headliner on my 55 and had a similar problem with the front two corners as well. I trimmed mine a bit and added some tabs to get it to fit better. I think it turned out pretty well, but it required me to put it in about 5 times before I ended up upholstering it.
On the door panels, I didn't use rod doors, but my father made similar ones from sheet ABS. I had the same issue as yourself with the dual lock holding the panel out beyond the reveal on the door. I decided to go with push in fasteners, which you can read about at the end of this thread
https://www.ford-trucks.com/forums/9...-f-series.html
I'm very happy with the fasteners. They were cheap and easy to find, easy to use/install on the panel, hold the door panel very securely, and don't threaten to tear apart my fingers or the door panel like the metal style ones.
Old Jan 11, 2010 | 04:23 PM
sdetweil's Avatar
sdetweil
see post # 12
just fyi, if you want to point to a specific post in a topic, click the 'permalink' link next to the reputation and report buttons on the post title bar.
the address area on your browser will now contain the direct, and permanent link to THAT post.. cut and past THAT text for the link in the message
here is direct to post 12 https://www.ford-trucks.com/forums/8...ml#post7100291
Sam
Old Jan 11, 2010 | 06:02 PM
raerjim's Avatar
raerjim
Don't I remember reading somewhere that Roddoors went the way of the buggy whip?
Old Jan 11, 2010 | 07:14 PM
bobs1948f1's Avatar
bobs1948f1
They did go out of business but one of the original guys is still producing the panels and selling them thru Classic Haulers & Mid Fifty's
bobs1948f1
Becky_is_a_66
Dec 16, 2015 02:12 PM
revenski
Ford Truck Parts for Sale
Oct 27, 2015 10:18 AM
jambottle
Sep 20, 2015 12:13 PM
mgraveman
1997 - 2003 F150
Jul 23, 2015 10:00 PM
Bob C. of Indiana
1983 - 2012 Ranger & B-Series
Oct 23, 2014 02:10 PM
