I need help fast....
Old Jan 7, 2010 | 05:29 PM
skierbri10's Avatar
skierbri10
Hey guys, my 95 5.8 was not heating up and since I just bought it I thought it would be a stuck open thermostat. Well, I am in the process of replacing it and there wasn't a thermostat installed. My problem now is which way does the new one install? I was hoping to see how the old one was but obviously cant do that. lol Thanks Brian
Old Jan 7, 2010 | 05:42 PM
Conanski's Avatar
Conanski
The spring side of the thermostat goes into the motor.
Old Jan 7, 2010 | 07:35 PM
skierbri10's Avatar
skierbri10
Thanks a bunch.
Another question. Now the temp guage actually moves but doesn't get up into the normal range. Anything I should look at? It gets past the C but not past the next line. Thanks!!!
Btw the heat coming out of blower is nice and warm now.
Old Jan 7, 2010 | 08:50 PM
LCAM-01XA's Avatar
LCAM-01XA
What thermostat did you install, what temperature it's rated at? I personally like the 192F on the Windsor engines, 180F is a bit too cold IMHO. Also, the factory gauge ain't really too accurate, you need something aftermarket to know what your truck's really running at.
Old Jan 7, 2010 | 09:03 PM
Conanski's Avatar
Conanski
These dash gauges typically indicate on the low side of the normal range, but if yours isn't getting over the mark at the left change the sender.. it's a small single wire unit at the very front drivers side on the lower intake.
Old Jan 7, 2010 | 09:09 PM
skierbri10's Avatar
skierbri10
It is rated at 192. I know it heats up now since the heater blows hot. I will check on the sender wire. Senders are pretty cheap too so I can replace that if the wire is good. Thanks your help.
Brian
Old Jan 10, 2010 | 06:29 PM
skierbri10's Avatar
skierbri10
I decided to replace the sender since it is a $5 part and no joy. Tried grounding the wire and no joy. Must be a broken wire somewhere, but with a newborn and a 2 year old time is tight. lol thanks for all your help. I may just install a real gauge.
rascal1
Aug 22, 2014 05:56 PM
a711112a
Mar 1, 2011 08:19 AM
PeeVee
13
Apr 26, 2008 11:02 PM
Innovative Detailing
16
Nov 18, 2006 02:29 PM
redmt77
Garage & Workshop
Jan 10, 2005 08:11 PM
