BW transfer case ?
Old Jan 7, 2010 | 04:11 PM
Roy C's Avatar
Roy C
BW transfer case ?
I have a 2003 Ranger, 4x4, 4.0L, 5spd manual tranny. The transfer case is a Borg Warner 1354. I was planning on changing the fluid in the trasnfer case but I can't locate the drain plug. I located the plug that is labeled "ATF Level" and it's up where the fill level should be at. Does anyone have a pic of these cases showing the drain plug?
Old Jan 7, 2010 | 06:20 PM
Rockledge's Avatar
Rockledge
The drain plug is behind the damper, which looks like an oversized steel hockey puck. You need to remove the damper (4 bolts) to get at the drain plug.
Old Jan 7, 2010 | 06:54 PM
Roy C's Avatar
Roy C
Rockledge,
Thanks for the help. I looked there but didn't see anything. Of course I'm wearing bifocals so that didn't help much.
Thanks again.....
Old Jan 7, 2010 | 08:14 PM
Rockledge's Avatar
Rockledge
Is yours a manual (mechanical) shift, or is it automatic (electric)? My advice is based on an electric shift. I'm not sure about the manual.
Old Jan 7, 2010 | 08:40 PM
reddog99's Avatar
reddog99
I'm sure that the manual shift is in the same place. I've drained both models, and the plug is behind the damper.
bulletpruf
Mar 10, 2020 01:09 AM
Fred Chartier
Escape & Escape Hybrid
Sep 5, 2016 09:53 AM
John Thomas II
Sep 21, 2013 08:40 AM
97ExpGuy
35
Jan 1, 2012 01:22 PM
90pioneer
Nov 2, 2011 08:49 AM
