Sponsored by: Real Truck
How Cold?
Old Jan 7, 2010 | 03:15 PM
07 F250 Aggie Mobile's Avatar
How Cold?
At what temperature should you plug in your engine block heater?
Old Jan 7, 2010 | 03:28 PM
Furian's Avatar
Furian
You Keep What You Kill
On Page# 182 of the 2005 Owner's Guide, it states the following:
"Use of an engine block heater is
strongly recommended if you live in
a region where temperatures reach
-10°F (-23°C) or below. For best
results, plug the heater in at least
three hours before starting the
vehicle. The heater can be plugged
in the night before starting the
vehicle. The plug for the block
heater is exposed in the front of the
vehicle, beneath the grille. Vehicles
equipped with a gasoline engine have the plug exposed on the driver
side of the vehicle; vehicles equipped with a Diesel engine have the plug
exposed on the passenger side of the vehicle."
I would think that anything temperature below freezing is acceptable.
Old Jan 7, 2010 | 03:29 PM
function12's Avatar
function12
I would say if you are not going to drive it all day Friday and Saturday (those are our big freeze days) I would plug it in. But if you drive it Friday and some on Saturday you will be OK.
Old Jan 8, 2010 | 08:54 AM
powerstroke72's Avatar
powerstroke72
I don't usually worry about plugging in unless it's going to be close to 0 outside. I've worked midnight shift the past two nights and it was 12 degrees yesterday morning and 9 this morning. It cranked a little slower than normal but fired right up with no problem. Now, had I been home, I probably would have plugged her in but there's nowhere at work to plug in. Biggest thing if you're not going to plug it in and it's going to be really cold is to make sure your batteries are good. Low batteries are going to crank much slower if at all and you'll risk frying your FICM if you're not careful.
Old Jan 8, 2010 | 10:22 AM
msgtg's Avatar
msgtg
I don't wait till it drops down that low to plug mine in. Ever seen 15-40 at 35 to 40 degrees? It's more like molassas! Why would you want to put that kind of strain on your engine during a cold start?
I plug mine in when it hits @40 degrees. I've heard that it makes some trucks dependent on it but I've not seen any evidence of that. I've had to leave mine at the airport for a week at a time during cold weather and she'll still fire right up...but she wants to buck, snort, and throw blue smoke for a couple of minutes before she smooths out.
Joe
Old Jan 8, 2010 | 10:38 AM
Big_Al59's Avatar
Big_Al59
If it's a gas engine you're ok following the manaul, if it is a diesel I usually plugged mine in around 10. It would start ok without being plugged in but it sure sounds better if ya do. You also might want to look into a heavy duty timer so that the heater comes on a couple hours before you need the truck. Most of the heaters are around 1500 watts so if you run it all weekend you might notice it on the electric bill.
Old Jan 8, 2010 | 07:15 PM
powerstroke72
Joe
Your 15-40 may look like molasses but my full syn 5-40 doesn't. Truck runs a little rough at idle for about 10-15 seconds and then smoothes out.
He's got a diesel.
Old Jan 8, 2010 | 07:17 PM
TexasRebel's Avatar
TexasRebel
you can plug it in at 100F If you want...
If I had one, I'd use it anywhere below 50F so I wouldn't have to wait so long for the cab to warm up...
Old Jan 8, 2010 | 07:32 PM
diesel-man1's Avatar
diesel-man1
Here in Alaska they advertise on TV they'd like for you to plug in at 20 degrees. That's the temp I use.
Old Jan 9, 2010 | 01:55 PM
BareBones's Avatar
BareBones
Guess I can't see +20 with a gasser, even with dyno. And with synthetic, that's got to be a joke......
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
