Another strange noise..need help
Old Jan 7, 2010 | 11:25 AM
dlambertjr's Avatar
dlambertjr
There is strange popping..kind of streching metal sound I can't quite explain coming from it seems just under your feet while in the driver seat. Only happens when starting off..or stoping. I have greased everything down there. Seems to be much less when its raining. The truck has 91,000 miles but is lifted. V-10. I know there other post on here about noises but they seem to be of a different nature. Any ideas? Wouldn't be a hub would it?
Old Jan 7, 2010 | 11:51 AM
tdappleman's Avatar
tdappleman
Does the truck pull to one side at all? Have you looked at your sway bar end links?
Old Jan 7, 2010 | 11:57 AM
dlambertjr's Avatar
dlambertjr
Sway bar end links look good. Truck drives perfectly straight, no wondering or pull. From a dead stop..sounds alomost like a worn out door hinge sound when your closing it..kinda screeching,popping. When I am just about to come to a stop, sound again. Otherwise no noise at all. Sounds like something is flexing or twisting. I don't know, but it drives me nuts
Old Jan 7, 2010 | 12:11 PM
tdappleman's Avatar
tdappleman
Might be ball joints - have you had the front end in the air to see if there is any play or noise?
Old Jan 7, 2010 | 12:17 PM
dlambertjr's Avatar
dlambertjr
Could be, they are little worn looking. Think I will start there..thanks
Old Jan 7, 2010 | 02:37 PM
Rickx's Avatar
Rickx
More than likely it's the body mounts. There is one directly under your left foot. You have to pull the kickplate and peel back the carpet to get to it. Tightening just the front ones got rid of this noise for me.
Old Jan 7, 2010 | 03:56 PM
superman_36's Avatar
superman_36
i had tha same sound and it was the body mount under the driver side floorboard
Old Jan 7, 2010 | 11:05 PM
tykateexcursion's Avatar
tykateexcursion
Mine just make a popping sound once and a while, I just deal with it.
2000 Ex LTD v10 2wd
Old Jan 7, 2010 | 11:45 PM
Monsta's Avatar
Monsta
Sit. Stay.
Rick nailed it.
Old Jan 8, 2010 | 09:01 AM
Hitagain's Avatar
Hitagain
Also look at your drivers side seat mount. Mine was loose and making a popping sound.
Old Jan 9, 2010 | 12:49 PM
seanreit's Avatar
seanreit
Does it sound kind of like a grinding noise and when you let off the accelerator it goes away? My 04 just started doing this a month ago and it's been driving me nuts as well. Seems to happen only when its cold and only during intermittent accelerations.
cwnitsuj
2004 - 2008 F150
Feb 12, 2013 08:13 PM
jonws77
1983 - 2012 Ranger & B-Series
Jan 6, 2004 04:11 PM
