the cam in my 429 requires a 2400+ stall on the tourqe converter what does the stock converter stall at and can i reuse it?
the c6 has a transgo stage 2 shift kit in it what kind of after market one will i have to look at it i need to replace
That's a pretty high stall. You should do some calculations regarding gears, tire size, & cruise rpm. If this is street driven, you are going to be plenty unhappy if your stall is higher than your cruise rpms methinks....
