Sponsored by: Auxito
Heat and A/C Problem
Old Jan 6, 2010 | 08:54 AM
Flareside50's Avatar
Flareside50
Hey guys, for a while now my truck has been just allowing the blower motor to come on in the highest and second to highest stage. When I switch it to low and the one directly above low it shuts off it seems like. I cannot here the blower motor running. Also sometimes if I have the heat and A/C on for a while the setting above the lowest will work. Please let me know what this is because its kind of annoying. Thanks.
Old Jan 6, 2010 | 04:21 PM
KingRanchMan02's Avatar
KingRanchMan02
Sounds like a blower motor resistor pack problem. Located above the passenger foot well and held into the duct with two screws. Pull it out and put in a new one. Good luck!
Old Jan 6, 2010 | 05:52 PM
steve(ill)'s Avatar
steve(ill)
yep, lay upside down on the passenger side floor and look up toward the glove box. Look for a 4 wire plug that goes to a small box about the size of a big isce cube, screwed to the air duct.. Remove it, one of the resistors is burn out on the back side.
Old Jan 7, 2010 | 02:06 PM
Flareside50
Thanks so much guys I took it out today and it was rusted and the connections were broken off. I replaced it and it works great now. Thanks.
RickBryan
Dec 3, 2012 08:47 PM
2002exPSD
Jul 29, 2012 06:29 AM
sp21
1997 - 2003 F150
Aug 20, 2010 11:00 PM
GWall
Dec 5, 2004 11:50 AM
PaulC
Jul 28, 2004 04:22 PM
