Sponsored by: Auxito
a/c blower motor not working
Old Aug 20, 2010 | 09:22 PM
sp21's Avatar
sp21
My a/c blower worked intermitently for a couple of days and then quit completely. i changed the switch no such luck. it is supposed to heat up to 100 degrees next week. I need to fix it. Any suggestions?
Thanks
Old Aug 20, 2010 | 11:00 PM
steve(ill)'s Avatar
steve(ill)
check fuses. lay on passenger floor and look up at glove box. look for a small block with 4 wires to it... 12 volts into resistors and 1-2-3 speeds out. If resistor is burnt, you get no speeds. check the 12 volt inlet power.
Chuck Fuller
Mar 26, 2015 04:47 PM
dfoxengr
Jul 29, 2012 09:01 PM
pjsbronco
Aug 29, 2011 01:01 PM
fordgirl07
1997 - 2003 F150
Oct 25, 2010 02:19 PM
vickieb
Aug 7, 2009 11:10 AM
