Diesel in crankcase
Old Jan 6, 2010 | 02:06 AM
Gagew90's Avatar
Gagew90
Diesel in crankcase
So I'm currently going through a nightmare of problems with my 7.3 but my main question right now is if injectors weren't seated properly when installed (its the last thing i had installed) could diesel somehow leak into the crank case
Old Jan 6, 2010 | 06:01 AM
rebelchevy02's Avatar
rebelchevy02
What were the condition of the injectors you installed, and did you change your oil when you installed them? Also how much diesel is in your crank? Im guessing it keeps rising?
Old Jan 6, 2010 | 07:23 AM
togobefastguy's Avatar
togobefastguy
if the injectors werent seated right or the o rings are bad wouldnt this cause diesel to get into the crankcase?
Old Jan 6, 2010 | 09:10 AM
Gagew90's Avatar
Gagew90
they were new (remanned) injectors with new o rings
changed the oil the next day and yes it does keep rising
Old Jan 6, 2010 | 12:24 PM
rebelchevy02
You probably have a cracked injector cup then. But before you can say that for sure, you could pull your injectors carefully, and inspect the o rings. If one is torn, more then likely it was that. But if they all look good, good change you have an injector cup that is cracked. That should be the only place for the fuel to get into the oil, other then rings. But you said before this nothing was wrong. When you re-installed the injectors, did you lube the o-rings with either oil or vasoline?
Old Jan 6, 2010 | 06:25 PM
DieselE's Avatar
DieselE
If your one or more of your cups were cracked or leaking this should put fuel in the coolant or oil in the coolant, not fuel in the crankcase, just my .o2
Old Jan 6, 2010 | 06:48 PM
rebelchevy02
Isnt that more of a headgasket thing? (oil in the coolant) Im pretty sure coolant doesnt go through any part of the injector? And the injector is seated into the cup. Please correct me if I am wrong. Because its not computing in my head at the moment.
Old Jan 6, 2010 | 06:49 PM
kccatpower's Avatar
kccatpower
i would try to dye your fuel and run the engine, then use a uv light to check for leaks around the injectors. at work we use a pump to connect to the inlet side of the head and plug the return line, pressurize the head and check for fuel leaks around the injectors. hopefully someone on here has done this on a 7.3 or can help you out more on setting one up. good luck
Old Jan 6, 2010 | 06:56 PM
CSIPSD's Avatar
CSIPSD
Injector cups will not cause fuel in the oil... They will cause fuel in the coolant
Correct.
Nope, Coolant cools the injector cup and the heads, when you have a cracked or lifted injector cup the 12psi coolant can not over come the 50-80psi fuel and you get fuel in your coolant.
To the OP, pull your valve covers and check all your injectors, make sure they are TQ'ed to spec and go from there. I would bet more then likely one is not seated, or the copper did not come out with the old injector.
Lets just hope you have not burned a hole in a piston.
Old Jan 6, 2010 | 06:57 PM
CSIPSD's Avatar
CSIPSD
This works great on the oil side, not so good on the fuel side...
Old Jan 6, 2010 | 07:03 PM
rebelchevy02
Thanks for the correction.
Old Jan 6, 2010 | 07:27 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
subscribing, need to know this stuff.
Old Jan 6, 2010 | 08:51 PM
Gagew90's Avatar
Gagew90
thanks for the input, the injectors were lubed before install my thought was that one wasn't seated but i supposed ill pull them all again and check for the copper washer thanks guys
Brettboat
Delaware Chapter
Jun 21, 2014 03:18 PM
akamacgyver
Jun 22, 2012 01:09 PM
silly34
Jul 26, 2009 02:37 AM
bio-d
Jul 18, 2008 01:24 AM
jimlj
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 25, 2007 08:47 AM
