wont run right?
Old Jan 5, 2010 | 06:52 PM
bigford705's Avatar
bigford705
wont run right?
so heres the thing, i went o leave in my truck the other day and everything was fine when i started it and let it warm up for 10 mins or so. I backed out of the drive way and when i went to leave in drive i got to about 1500rpm and the truck got a really rough idle to the point where it would stall if i didnt get it into neutral or park? it only does it going foward it wont do it in reverse? it also isnt setting off the check engine light so im kindof stuck here. any help would be great!! thanks guys.
Old Jan 5, 2010 | 07:13 PM
rideracelivemx7's Avatar
rideracelivemx7
When you start it in park does it run bad aswell? Rough idol or loping? How. About starting in neautral, does it change?
Old Jan 5, 2010 | 07:19 PM
bigford705's Avatar
bigford705
No it runs great until you go to drive it. when its starts to idle really rough just before it stalls i can put it into neutral and it all clears up? Maybe a pcm issue im not too sure. I havent tried starting it in neutral ill have to try!
Old Jan 5, 2010 | 07:21 PM
bigford705's Avatar
bigford705
the thing i have tried tho is i pulled the fuse for the speedometer and i could go foward with out a problem but it would not shift gears.
Old Jan 5, 2010 | 08:50 PM
yoslick's Avatar
yoslick
Sounds like the torque converters locking up prematurely..
Walwal44
Feb 2, 2015 05:12 AM
Will Walters
Aug 4, 2012 10:01 AM
benbo30
Mar 14, 2012 03:58 PM
McKenzie7.3
37
Jan 10, 2012 01:47 PM
Dave06FX4
2004 - 2008 F150
Jan 30, 2011 06:37 PM
