Do it myself or Schwabs?
Old Jan 7, 2010 | 01:38 PM
  #31
YoungFordAddict66's Avatar
YoungFordAddict66
offrdmania what do u mean no drop down bracket and why the front brake lines? and the closest shop is 4 miles away and its schwabs.
Old Jan 7, 2010 | 01:43 PM
  #32
offrdmania's Avatar
offrdmania
Usually there is a union for the brake line on the frame rail. You will have to undo the clip holding it to the frame and connect it to the bracket supplied in the kit. You are dropping your suspension down so you want to move the brake line down with it otherwise you will stretch the line. The rear brake line will most likely have a bracket to lift the brake line off of the rear end housing.
