IDM Mod Resistors
Old Jan 6, 2010 | 09:55 AM
Talyn's Avatar
Talyn
You are supposed to have metal film resistors on them.
Using cheepo's is just asking for disaster. Using a 1/4 or a 1/2 watt over the 1/8th watt will give you more longevity on them as well.
Your changing around the voltage in the system with a resistor. You want it to be right, otherwise your creating excess heat, which will kill the resistor.
Old Jan 6, 2010 | 10:20 AM
chicagodragon's Avatar
chicagodragon
for the IDM, a metal film resisto is only used because of space. the 100-140v is not passing through the resistor.
Old Jan 9, 2010 | 04:22 PM
bpayne88's Avatar
bpayne88
so you can use the say 75 ohm 1/4 or 1/8 watt 5%resistor from raido shack?
Old Jan 9, 2010 | 04:25 PM
chicagodragon
the % is the accuracy of the resistor. put it on an ohm meter to see if it is a true 75k ohms, you might have to put a 1 or 2k inline to get 75k.
Old Jan 12, 2010 | 01:11 PM
blue66tang95f150's Avatar
blue66tang95f150
Anybody want to help me find an IDM. I checked all the wrecking yards around here and they were all either bought by one guy, or want 200+ bucks for one. I thought they would be like around 50 bucks?
Old Jan 12, 2010 | 01:50 PM
chicagodragon
rebuilt ones on ebay for 169 95 96 Ford 7.3L Powerstroke Injector Driver Module IDM:eBay Motors (item 170373649067 end time Jan-21-10 03:00:00 PST)
Old Jan 12, 2010 | 07:40 PM
blue66tang95f150
Yeah I saw those, I was hoping to find just a cheap used one I could rip into and do the IDM mod. I know I know I am cheap.
Old Jan 12, 2010 | 09:45 PM
Oversize's Avatar
Oversize
So whats the verdict as Im not an electrical guru do we need the special resistors or what?
Old Jan 13, 2010 | 09:40 AM
chicagodragon
i see no need for it.before i did the mod, i researched it for as many pic as i could find, and they almost always used cheap resistors. just test them first to make sure they are a true 75k. you may need to put two in line, i did.
Old Jan 14, 2010 | 11:45 AM
Talyn's Avatar
Talyn
yea, IDM's are not Cheep.
If i can get ahold of them, I know i'm going to get the steal on them or no go.
Tominky
2009 - 2014 F150
Jun 10, 2017 03:51 PM
Rocketattack
Apr 25, 2016 09:00 PM
jyates2007
Oct 18, 2015 11:24 PM
110
Jan 16, 2014 03:29 PM
70T351W
Electrical Systems/Wiring
May 30, 2005 08:20 AM
