L&L headers
Old Jan 4, 2010 | 07:53 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
L&L headers
I was going to order the L&L fenderwell exit headers but I found a bulletin that stated that they wouldn't fit a f250 4x4 without a 3" body lift. Is this the case or will they fit a regular f250? The truck is a 1978 f250 4x4 460 c6 and a 4" suspension lift. I would rather have the fenderweii exit rather than the shortys for ease of working on stuff. Thanks for the help I'm sure someone here knows.
Old Jan 5, 2010 | 09:54 AM
mark a.'s Avatar
mark a.
I have them on mine but I already had a 3" body lift. I don't see any reason why they wouldn't work, either way you have to trim the inner fenders.
Old Jan 5, 2010 | 11:57 AM
Broncoholic1's Avatar
Broncoholic1
They fit with out the body lift. Just have to cut the inner wheel wells/
Old Jan 6, 2010 | 11:40 PM
wyoming4x4's Avatar
wyoming4x4
Good headers!
Been running LnL header for almost 20 yrs. good product. Starter is easy to work on with fender exit headers. Starter doesn't get hot and wear out premature with headers near starter. highly reccomend getting metal gaskets for headers. Paper gskts will blow out. Once you install headers and torque up, drive and get hot and let cool down and doublecheck/retorque. Once you do this on first day you'll be good to go and no header leaks. The few times I've had header leaks it was operator error.
Old Jan 7, 2010 | 08:54 AM
Broncoholic1
What kind of gaskest did you use?
Old Jan 7, 2010 | 09:17 AM
78BroncoMP's Avatar
78BroncoMP
I'm looking at a L&L catalog and according to this, 1967-76 f250/f350 requires a 3" body lift, 1977-79 f250/f350 429/460 4wd fenderwell exit header #79750B, doesn't have a note for a body lift. Verify before ordering. http://www.l&lproducts.com/ or phone # 972-475-5202. I've talked with them before and they know their product and applications very well. They would be able to tell you why it needs a body lift, but it doesn't look like it does.
Old Jan 22, 2010 | 11:54 PM
lannondiesel's Avatar
lannondiesel
I have L&L Fenderwell exits on my 79 F-150 4x4 SWB with a 460 and a 1.5 body lift and they fit no problem so I know for sure you shouldnt need 3" lift. I absolutely love these headers, the best headers I have ever purchased.
Old Jan 25, 2010 | 05:14 PM
jbrown9709's Avatar
jbrown9709
Chalk me up as one more using L&L fenderwell headers with no body lift. Minor trimming of fender liner required. Truck is 79 F250 with 4" susp. lift. Side note: I do get tire rub on driver side header with 35" tires at full lock. It's worse if side spring is compressed. It was much worse before I swapped wheels for some with major offset.
Jeff
Old Jan 26, 2010 | 12:26 PM
mark a.'s Avatar
mark a.
Jeff
Have you tryed readjusting the axles steering stops ?
Old Jan 26, 2010 | 12:45 PM
Broncoholic1
He has leaf spring wheel stops...
Old Jan 26, 2010 | 10:21 PM
wyoming4x4's Avatar
wyoming4x4
Felpro stuff metal gskt.
Been running felpro metal gskt. It takes a little time torqueing up header properly and evenly. Alot of it can be done with a 1/4" ratchet and need a small wrench in a few spots. Once all torqued up use small wrench on all bolts to make sure even torque and then go drive and get hot. Let cool down and retorque. One other thing is start torque in the middle like doing a cyl head. Might find acouple needing a little torque and then snug up. Every once in a while I'll recheck because they are headers. Been very pleased with this product. I know their are some other gskts out their but these have worked just fine and reasonable on pricing.
Old Jan 27, 2010 | 09:05 AM
jbrown9709's Avatar
jbrown9709
I'd rather have the extra turning radius in a pinch so I just try to be conscious of rubbing.
william16339
Dec 22, 2016 04:55 AM
dmccorkle911
Jun 27, 2014 10:42 PM
ArmedSuperman44
Jun 9, 2013 12:48 AM
johnson2007
Feb 10, 2011 11:53 PM
gingerbreadmaniac
Jun 21, 2009 02:02 PM
