Timing question
Old Jan 27, 2010 | 11:15 AM
kitfarley's Avatar
kitfarley
Timing question
I replaced intake gaskets on my '95 460 and cannot get it to start. After getting everything back together I turned it over until the timing pointer on the damper was pointed at the 0* which should be TDC. put my plug wires in firing order counterclockwise starting where the rotor was pointing with number 1. I get a couple of backfires and it tried to start a couple times. Can it be 180 degrees out?
Old Jan 27, 2010 | 12:20 PM
Bear 45/70's Avatar
Bear 45/70
Yes, you are 180° out. Next time set the engine at TDC (rotor pointing at #1) mark the dist. housing to the block, the rotor to the dist. and you won't have this issue.
Old Jan 27, 2010 | 02:27 PM
kitfarley's Avatar
kitfarley
Can I just flip distributor cap 180* to resolve?
Old Jan 27, 2010 | 03:06 PM
lew52's Avatar
lew52
You can pull the distributor out & turn the rotor 180 & put it back in ...Lew
Old Jan 27, 2010 | 04:04 PM
Bear 45/70's Avatar
Bear 45/70
No, you can't rotate the cap, it has locating tabs. Just rewire the cap.
