e4od tranny problems!!!!!!
Old Jan 4, 2010 | 06:49 PM
phantom 309's Avatar
phantom 309
i have a 93 f250 naturally aspirited diesel.i have had trouble with the tranny. at first the overdrive button burnt up, i replaced that. a few miles later had more problems it would shift hard and couldnt decide what gear to be in. so i put a used tranny in it. at first the range sensor was bad i replaced that. then i had problems again! the overdrive button would flash the <NOBR id=itxt_nobr_1_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">truck</NOBR> would rev up a lil bit and in between shifting gears it would rev up. the ford dealer told me that they hooked the computer to it and the problem was a speed sensor that was either the one in the cluster or the one that goes to the computer. i replaced the cluster but now when it gets cold it does the same thing. is it the speed sensor that goes to the ecm? if anybody knows what could be wrong please tell me i am fed up!
Old Jan 4, 2010 | 08:48 PM
Popa Tim's Avatar
Popa Tim
The one for the cluster is just for the speedo. The ECM would use the other one to figure out where/what the transmission should be doing.
Old Jan 4, 2010 | 09:54 PM
phantom 309
do u know where the sensor that goes to the ecm is located?
Old Jan 4, 2010 | 10:10 PM
phantom 309
do u know where the speed sensor that goes to the ecm located on my truck?
Old Jan 5, 2010 | 07:01 AM
subford's Avatar
subford
Your speed sensor (VSS) for the transmission and the one for the cluster is the same part.
It is located on top of the rear end and in 93 it was call the DSS.
The path for the information from the rear end DSS is to the PSOM (inside the cluster) and then on to the computer.
The DSS, ABS or VSS sensor in the rear end:
Old Jan 10, 2010 | 08:26 PM
phantom 309
e40d tranny speed sensor trouble
i replace my speed sensor on the differential on my 93 f-250 diesel at first i drove it and the speedometer bounced all over and the overdrive button flashed. i shut the truck off and tightened down the sensor took it out again the seepdometer worked fine but the light still came on again. i think it might be the pigtail to the sensor because the tabs on the side broke off. but idk. does anybody know what might of went wrong?
Old Jan 10, 2010 | 09:29 PM
subford's Avatar
subford
If it is not the VSS then it may be the ABS module or the PSOM.
You will have to put a meter on the test point and run the truck up to 30 MPH and see what reading you are geting in ACV.
Old Jan 11, 2010 | 06:09 AM
phantom 309
its the speed sensor because the ecm was giving a speed code and before i replaced the sensor the overdrive button would only flash when it was really cold out. now it blinks right away.
Old Jan 11, 2010 | 07:00 AM
subford's Avatar
subford
A speed codes means the PCM (EEC as you call it) is not getting good information from the PSOM. If the PSOM is not giving out good information it could be as I said above, a bad VSS, Wiring between them, ABS module or the PSOM.
Of you are getting this speed code from CM then clear the codes as the code could be old.
Old Jan 11, 2010 | 05:44 PM
phantom 309
i had put a 3 inch lift on it and bigger terra grappler tires would that have an effect on whats happening?
jdavis_apd
Feb 27, 2010 01:32 PM
1stTruck
Jan 10, 2010 11:51 PM
boaterdude83
Jan 6, 2010 09:03 PM
chris5301
1997 - 2003 F150
Jan 2, 2010 07:28 AM
