Power door lock question
Old Jan 3, 2010 | 04:21 PM
utjer's Avatar
utjer
Question Power door lock question
I tried this earlier on another section with no replies so I will try here. I have a 2003 f350 crew cab. The power locks work just fine by hitting the button on the door or remote. They all lock o.k. when the vehicle starts to move. The question I have is that when they unlock when the vehicle is put into park, only the front doors will unlock. The rear doors do not and I have to either pull the lock up or hit the unlock button. The child safety locks are off. Does anyone have any ideas or is this just another quirky ford issue?
Old Jan 3, 2010 | 04:26 PM
gearloose1's Avatar
gearloose1
Get a schematic, and find out what circuit does the "Park" unlock.
Meanwhile, do a reset of the PCM/GCM by disconnecting the battery and turning headlights on for 2 minutes.
See if that clear the gremlins.
Old Jan 3, 2010 | 04:29 PM
utjer's Avatar
utjer
Thanks gearloose1, I will give that a try tonight.
Old Jan 3, 2010 | 06:21 PM
johnnysF350's Avatar
johnnysF350
I dont think the rear doors unlock automatically. As a matter of fact I think they all just lock auto but dont unlock. The front doors in Fords are designed to unlock automatically when you pull the interior door handle so I never really paid that close attention. The child safety locks just disable the interior handles they have no function over the actual door lock.
Old Jan 3, 2010 | 06:23 PM
gearloose1's Avatar
gearloose1
johnnys....
Could it be that the "unlock" in park is intended to ONLY unlock the front doors automatically by design?
It would make sense not to unlock all doors!
Old Jan 3, 2010 | 07:01 PM
69cj's Avatar
69cj
Originally Posted by gearloose1
johnnys....
That is what I'm thinking since I'm to lazy to check the book right now. I disabled the auto locks. If I want them locked I know where the switch is.
Old Jan 3, 2010 | 07:46 PM
2005Dually's Avatar
2005Dually
None of my door locks ever unlock when I put the truck back into park. Been that way since day one.
Old Jan 4, 2010 | 07:36 PM
johnnysF350
Yes it's by design, they probably figure that kids are in the rear most of the time and they dont want the doors automatically unlocking for them. I havent been out to check my truck but i believe that it is the same as what 2005Dually said, none of them unlock. The only time I have ever had my truck unlock the front doors is if I try to lock it with the key in the ignition. Are you positive that your fronts are unlocking when going into park? because if you pull the front door handles in any Ford the door will unlock and open...
Old Jan 4, 2010 | 07:43 PM
gearloose1's Avatar
gearloose1
On many of these systems, it is possible to program it to do different things using the Body Control Module.... at the friendly Ford Dealer.
Old Jan 5, 2010 | 11:52 AM
utjer's Avatar
utjer
Thanks for the info guys. I double checked what I am seeing. My doors do not automatically unlock. The fronts will unlock when the handle is pulled on. The rears will not with the handle being pulled on. I have to hit the unlock button or pull the lock up manually.
Logan1080
Jul 30, 2021 12:46 AM
PsychoBilly74
Jan 21, 2017 07:17 PM
99cummins
Dec 18, 2013 09:45 AM
sethjamto
Jul 21, 2011 11:14 AM
BigDog83
Jun 19, 2008 12:02 PM
