Driver door mysterically unlocks..
Old Jul 20, 2011 | 03:48 PM
sethjamto's Avatar
sethjamto
Yesterday I gave both my door lock mechanisms a good shot of WD40 as one of the switches was sticking and leaving my dome light on. That seemed to solve the problem, but this afternoon when I got home from work and opened the door, hit the lock button, and turned to grab something out the seat, I heard it unlock (just the driver's side). Hummmm....hit the lock botton again, and about a second later.....yup.....it unlocked itself (just the driver's side). I tried locking it with the switch on the passenger door and it did the same thing. Next I manually locked it by pushing the door lock itself down. This worked, and it did NOT unlock itself. I unlocked and tried the door switch.....yup, the ghost was back.
Any ideas??????
Old Jul 20, 2011 | 04:20 PM
florida_1959's Avatar
florida_1959
I know it seems kind of simple, but happened to me before. It may or may not be the answer but make sure all the doors are closed tightly. For some reason my 2006 wont stay locked (drivers door) if there is another door cracked open. This only happens when i use the key fob or the door switch to lock, manually it stays down.
Old Jul 20, 2011 | 05:23 PM
cheezit's Avatar
cheezit
foor lock acuator is bad
Old Jul 20, 2011 | 06:02 PM
rrrrick's Avatar
rrrrick
My truck did that a few months ago, I thought I had gone crazy....push the lock button and the drivers door would unlock after a few mopments
I worked the drivers door lock button up and down a few times manually and the problem went away. I don't know what caused it, only how I fixed it.
Old Jul 20, 2011 | 06:14 PM
JESTERxHEAD's Avatar
JESTERxHEAD
LMAO...I have never heard of this.....kinda funny and bad at the same time...
Old Jul 20, 2011 | 08:11 PM
sethjamto's Avatar
sethjamto
I'll give it a try tomorrow!
Funny, yes....a little weird too!
Old Jul 20, 2011 | 08:36 PM
kaliman78alfa's Avatar
kaliman78alfa
Water inside the controls?
WD40 isolates/displaces water, maybe a little moisture spreaded inside the controls turned into a drop of water in one of the contacts of the LOCK button, happened to me before... Good Luck!
Old Jul 20, 2011 | 09:02 PM
rollerstud98's Avatar
rollerstud98
I thought it was a safety thing to help you not lock your keys in the truck? Mine has always done this so I never thought twice about it.
Old Jul 21, 2011 | 08:35 AM
rocknut's Avatar
rocknut
mine does the same once and awhile. But using the button on your remote works fine
Old Jul 21, 2011 | 11:14 AM
mblanken881's Avatar
mblanken881
If the door is open and the key is in the ignition the drivers side door should unlock. Its to help keep you from locking your keys in the car.
stowbilly96
Mar 22, 2020 07:35 PM
fruitcake1234
Oct 15, 2013 06:04 PM
detill
Aug 29, 2013 06:23 AM
Kmundt76
Oct 31, 2012 01:49 PM
totalrecall
17
Sep 4, 2012 02:27 PM
