351 W engine ID
Old Feb 20, 2000 | 08:28 PM
78F100's Avatar
78F100
351 W engine ID
Can somebody ID the engine that I just bought for my truck? The seller told me it came from Ford Engineering and was a warranty return with low hours. The warranty tag says engine mount pad was cracked and has been repaired, I can see it has been welded and drilled/tapped.
I was told it has GT40 lower intake and heads.
info on the motor is:
valve cover label- Pleasurecraft Marine Engine
Mod.PPRR12EFI
Firing Order 13726548
Cert No. (M12) 11 1 94 03
intake casting no.- PFF2JE9K461BA 017 NHI
cyl. head casting no.- GT 66 (or 99?)heads have
3 ridges cast into the end
block casting no.- F4TE 6015 AA13
Old Feb 20, 2000 | 09:36 PM
77_F150_4x4's Avatar
77_F150_4x4
351 W engine ID
gliderdad
Mar 27, 2009 11:40 PM
76 F-150 390FE
Jun 25, 2008 01:36 PM
b17goinmyway
19
Sep 20, 2007 09:37 AM
ronclark
Apr 14, 2005 01:50 PM
krazmechanic
Apr 25, 2004 02:24 PM
