I this weekend i took off my power steering pump turned it fluid came out so i figued it was still good i took off the cooler line blew it out put it back on blew out the other line put the pump back on put the fluid back in it made sure everything was tight then turned the key turned the wheel to the right lock it had power steering then to the left lock it was gone took it driving nothing no power steering it only has 29s on it what is the problem help.???
You may have air in the system. Try raising the front end off the ground, and barely loosen the return line and turn the wheel lock to lock about 25 times, and tighten it back down, add more fluid and try it again.
You did add power steering of type F tranny fluid, right?
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
