P1670 and other stuff
I've been chasing a smokey start situation for a while now and I got this code with an AE scanner. I just got the scanner and have a few other codes including:
P0380 Glow Plug/Heater Circuit A (probably since i have a manually controlled GPR
P0603 Internal Control Modulke Keep Alive Error (Recently replaced one battery and had both batteries out to do the injector O-rings)
P0541 Intake Air Heater A Circuit Low (since i have deleted the heater)
I also had:
P0269 Injector 3 Circuit Contribution/Balance Fault (Change Rotational Velocity 3.7-4.2 % at idle after warm-up)
P0284 Injector 8 Circuit Contribution/Balance Fault (Change Rotational Velocity 3.6-4.9%)
Of all of this, i am most concerned about the P1670. I wanted to check conections to the box and look for wire problems. However, I haven't been able to find the module. Where is it located?
THanks
I also had:
THanks
Truck runs fine on the road but start ups started to get smokey (blue-white) a few month ago. I replaced all injector O-rings and definitely found two on the same injector that appeared to be damaged. That cleared up much of the smoke.
The smoke on start-up appears more white now. No coolant loss or oil/fuel in the coolant that i can see.
Any ideas on the remaining smoke greatly appreciated.
Thanks
dlragalie
03-07-2017 08:38 PM
