heater issues
Old Jan 2, 2010 | 12:13 PM
wib714's Avatar
wib714
heater issues
anyone know what may be going on here. 2000 4wd 3.0 flex. heater and fan are blowing hard and will burn you out of the truck like most fords but when I am accelerating down the road its almost like I shut the vents on the dash, you can still hear it blowing but nothing is hardly coming out. let off the pedal to an idle and after a second or two it will start blowing your hair back. accelerate again and it just blows inside the dash again. any thoughts? something in my vents blocking it off and on, heater core, I have no ideal.
Old Jan 2, 2010 | 06:57 PM
03 Maz B23's Avatar
03 Maz B23
There is a vaccuum operated blend door in the heater assembly and it sounds like yours has a leak in the vac line that attaches to it.
Old Jan 2, 2010 | 10:23 PM
Rockledge's Avatar
Rockledge
As noted, you have vacuum leak in the somewhere in the HVAC system. Check out my posts in this thread: https://www.ford-trucks.com/forums/7...s-on-feet.html
Old Jan 3, 2010 | 08:35 AM
wib714's Avatar
wib714
I seen in a post the guy was having the same problem and his 4wd was not locking in too, are these vacuum lines linked to the 4wd as well as mine is not locking in either, but I think my 4wd has been out longer than my heater issues.
thanks for the link, will look into this when it warms up a little, its 5 degrees out today and I have no garage, truck does get warm hopefully it just wont get worse.
Old Jan 3, 2010 | 09:51 AM
Rockledge's Avatar
Rockledge
If your '00 has the pulse vacuum hublock (PVH) 4WD engagement system, then yes, it shares the same vacuum source and lines as the HVAC system.
If it were mine, first thing I'd check is the vacuum reservoir tank and lines going to and fro:
Ford Truck Enthusiasts Forums - View Single Post - air shifts from vents to defrost on its own and back again
Ford Truck Enthusiasts Forums - View Single Post - problem #3 in my 1998 ranger
Old Jan 3, 2010 | 12:33 PM
wib714's Avatar
wib714
thanks rock, you da man!
