Tail lights
Old Dec 31, 2009 | 05:02 PM
freightshaker69's Avatar
freightshaker69
Tail lights
one works the other turns off when i put my brakes on then when i release them it comes on again ive looked at the wires put new ones in put that elec greese in the tube i dont know its driveing me crazy this is on a 76 ford 250
Old Dec 31, 2009 | 06:45 PM
JimsRebel's Avatar
JimsRebel
Try adding a new ground wire, just us a jumper wire, to see if it helps.
The tail light might be finding its ground thru the brake light filaments.
Old Dec 31, 2009 | 11:31 PM
Franklin2's Avatar
Franklin2
Yep, sounds like a ground problem. It could be the connection in the socket from the brass part of the bulb to the little tang in the socket. It could be the connection inside the socket that goes to the wire coming out of the socket(I have had this happen to me twice), or it could be where the ground wire actually bolts to the bed.
Old Jan 1, 2010 | 10:52 PM
craftsmangary's Avatar
craftsmangary
the ground wire on the harness usually is grounded to the rear crossmember near the left frame rail
Twosnl
Escape & Escape Hybrid
Mar 22, 2011 09:40 PM
silver9696
Jun 27, 2010 12:30 AM
bmaltb
Apr 5, 2007 01:01 PM
guillermojm
Oil & Lubrication
Nov 11, 2005 01:38 AM
