Tail lights
Old 12-31-2009, 05:02 PM
freightshaker69's Avatar
freightshaker69
freightshaker69 is offline
Tail lights
one works the other turns off when i put my brakes on then when i release them it comes on again ive looked at the wires put new ones in put that elec greese in the tube i dont know its driveing me crazy this is on a 76 ford 250
Old 12-31-2009, 06:45 PM
JimsRebel's Avatar
JimsRebel
JimsRebel is offline
Try adding a new ground wire, just us a jumper wire, to see if it helps.
The tail light might be finding its ground thru the brake light filaments.
Old 12-31-2009, 11:31 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,788 Likes on 1,443 Posts
Yep, sounds like a ground problem. It could be the connection in the socket from the brass part of the bulb to the little tang in the socket. It could be the connection inside the socket that goes to the wire coming out of the socket(I have had this happen to me twice), or it could be where the ground wire actually bolts to the bed.
Old 01-01-2010, 10:52 PM
craftsmangary's Avatar
craftsmangary
craftsmangary is offline
the ground wire on the harness usually is grounded to the rear crossmember near the left frame rail
Twosnl
Escape & Escape Hybrid
03-22-2011 09:40 PM
silver9696
06-27-2010 12:30 AM
bmaltb
04-05-2007 01:01 PM
guillermojm
Oil & Lubrication
11-11-2005 01:38 AM
Quick Reply: Tail lights
