Sponsored by: Auxito
maf sensor interchangability
Old Dec 30, 2009 | 04:59 PM
orlmailman's Avatar
orlmailman
my 99 f150 with 5.4 had a junky aftermarket air intake I went to the junkyard and got a stock airbox intake assembly out of a 97 expedition with the 5.4 both vehicles have the same vin code for the motor the maf sensor setup is a little different in the 97 expy will it work ok with the 99 f150
Old Dec 30, 2009 | 06:38 PM
torkum's Avatar
torkum
If your 99 is a non PI motor you should be ok. Some 99s have PI heads and I would think the parameters of the MAF would be different because of the hp difference.
Old Dec 30, 2009 | 08:26 PM
orlmailman's Avatar
orlmailman
how do you tell if you have pi heads my engine vin code is L the expedition has the same letter vin number for the engine thanks
Old Dec 31, 2009 | 02:39 PM
Ron W.'s Avatar
Ron W.
There will be a decal on the drivers side valve cover that's a little hard to see but will have your engine code on it. The code will be 2digits-3numbers-2letters, post the code and I can tell you if it's a P.I. setup.
In my opinion you'd want to use a M.A.F. sensor with the same ID number as the one you took off.
Good luck
Old Jan 2, 2010 | 11:16 AM
orlmailman's Avatar
orlmailman
this is what the whole sticker says
9g876ba
ford windsor ontario canada
983382055
555 12-4-98 54l
thanks
Old Jan 2, 2010 | 11:58 AM
Ron W.'s Avatar
Ron W.
9g876ba
983382055
555 12-4-98 54l
thanks
9G-876-BA is your code and yes it is a "power improved" engine.
You're welcome
Old Jan 3, 2010 | 08:21 AM
orlmailman's Avatar
orlmailman
if you don't mind me asking what is a power improved engine I saw the serial number on the head yesterday when I was changing o2 sensor it had pi after it so I kind of figured they were pi heads thanks for the info
Old Jan 3, 2010 | 10:52 AM
sprky_02's Avatar
sprky_02
The PI Heads had a few changes to casting, valves and the cam design and the way that they time. Take the heads off and the Blocks and internrals are same, only difference in engines for these are whether they are a Romeo or Windsor engine. The PI heads and cams are a nice swap into the non PI Mustangs, Thunderbirds, etc. Feels like a power adder has been added in those cars when you do the change.
Old Jan 3, 2010 | 11:14 AM
orlmailman's Avatar
orlmailman
I guess I will go back to the junk yard and get a housing that will take my original maf sensor.
Old Jan 3, 2010 | 11:27 AM
sprky_02's Avatar
sprky_02
Use this site for cheap parts and also to compare any part for interchange info.:
RockAuto Parts Catalog
Just after looking your year model and part up, look at where the part number is typed in blue, click on that and it will tell you every vehicle the part was used on!!!
Yours for the Mass Air Flow Sensor showed this:
<table id="buyersguidetable"><tbody><tr class="part0"><td>FORD</td><td>EXPEDITION</td><td>(1999 - 2002)</td></tr><tr class="part1"><td>FORD</td><td>F-150</td><td>(1999 - 2003)</td></tr><tr class="part0"><td>FORD</td><td>F-150 HARLEY-DAVIDSON EDITION</td><td>2001</td></tr><tr class="part1"><td>FORD</td><td>F-150 HERITAGE</td><td>2004</td></tr><tr class="part0"><td>FORD</td><td>F-250</td><td>1999</td></tr><tr class="part1"><td>FORD</td><td>F-250 SUPER CAB</td><td>1999</td></tr><tr class="part0"><td>FORD</td><td>F-250 SUPER DUTY</td><td>1999</td></tr><tr class="part1"><td>FORD</td><td>F-350 SUPER DUTY</td><td>1999</td></tr><tr class="part0"><td>FORD</td><td>F-450 SUPER DUTY</td><td>1999</td></tr><tr class="part1"><td>FORD</td><td>F-550 SUPER DUTY</td><td>1999</td></tr><tr class="part0"><td>FORD</td><td>TAURUS SHO</td><td>(1996 - 1999)</td></tr><tr class="part1"><td>LINCOLN</td><td>BLACKWOOD</td><td>2002</td></tr><tr class="part0"><td>LINCOLN</td><td>NAVIGATOR</td><td>(1999 - 2002)</td></tr></tbody></table>
Very helpful when you have a $100 $200 or $300 item that you are gonna have to replace that you could get out of the junk yard, even sometimes you'll find parts that are used between different car manufacturers, just remember the risk involved in using a CHEVY part on your FORD!!!! LOL!
6t56
Jan 18, 2012 07:45 PM
mdpitt
1997 - 2003 F150
Sep 1, 2007 05:11 PM
TallPaul
Apr 20, 2007 12:06 PM
Stryker472
1997 - 2003 F150
15
Mar 1, 2007 12:24 AM
97expy5_4
Modular V8 (4.6L, 5.4L)
Jul 30, 2001 12:57 PM
