Clutch problem
Old Dec 29, 2009 | 03:49 PM
cabloom300's Avatar
cabloom300
Clutch problem
My truck ran fine yesterday and went out today and stepped in and the clutch had a ton of play at the top and close to the floor it got some tension but odviously the clutch wasent engaging because i couldnt get it into gear. I have no idea what the problem is. The only thing that i can think of is i got the clucth hot and smelly about 4 days ago when i was trying to get unstuck but it ran fine after that until today. Anyone know whats wrong?
Old Dec 29, 2009 | 08:52 PM
pimpstang18's Avatar
pimpstang18
check the bushing on the clutch pedal where it connects to the master on the inside of the firewall. it's usually a plastic piece of crap, very weak, if you snapped it then the pedal could slide off the rod. this would cause a ton of play at the top and the tension at the floor could be when it's being pinned against the spring...easy fix, just put it back into place with a retaining clip but make sure the clutch still engages properly or else you might just need to replace the entire assembly
hdatboy04
Dec 23, 2014 03:22 AM
Snowturtle
Aug 19, 2014 09:16 AM
cabloom300
Jan 22, 2013 10:51 PM
fixit5561
Aug 7, 2010 08:14 AM
DJdemon6696
25
Dec 14, 2009 04:08 PM
