Clutch pedal comes way to far out towards the dash?
I got in my truck today after driving it quite a bit today and i notice the clutch pedal reciedes way up near the bottom part of the dash. It looks like theres only 1 big spring underneath by the linkage. Would that possibly have wore out or is there something im missing? The clutch itself is fine after taking it for a trip to confirm, the problem seems to be in the pedal. What should i look for? Oh and truck is a 2000 Thanks
just in case...IF you have to replace the master, i'd just get thee entire assy...
Buy Perfection Clutch Pre-Filled MST/SLV PF9021 at Advance Auto Parts
Advance Auto Parts
Advance Auto Parts
There is no bleed screw so all the bubbles have to come out the top. once the new master is installed, fill with fluid and leave the cap off.now simply pop the slave out of the bell housing and slowly push the rod in and release. about 25 times. recheck level and install cap. try you clutch. if it feels right, you're good. if its still a little soft, re-bleed. shouldn't be too much if all you change is the master. takes a little more if you're doing the slave.
Barney
I stopped at Ford and they didnt seem to have any idea what i was talking about or what the problem could be. I was checking online a saw a part number but it was for the piece that holds the pedal arm to the mount itself but i still have that. Where does the clip go? Is it somewhere on the rod itself? I have to find a part number somewhere but im not sure how. I cant seem to find any pics that help, or show me what im looking for either.
Brad_81Ford
11-04-2011 07:56 PM
donberry
11-02-2011 09:13 PM
Styrrell36
02-08-2007 10:18 AM
