Rebuilding an E4OD
Old Dec 29, 2009 | 02:54 PM
George D.'s Avatar
George D.
Rebuilding an E4OD
Well suposably my forward clutches went out in my trans, so it looks like its rebuild time. I want to get red eagle frictions and kolean steels and an 4r100 blanitary set. What els should be replaced/ upgraded
Old Dec 29, 2009 | 04:14 PM
David85's Avatar
David85
Center support upgrade to roller bearing (it may already have this)
Steel forward and overdrive gears
F5 (1995 model) front pump and either transgo or sonnax correction kit
Upgraded front seal (blue)
Billet cover torque converter
3 friction overdrive clutch (should already have this)
Cooler return line filter
There is a long list of other upgrades, but I don't have that book with me right now. You are starting with a pretty good year of transmission, so even if you rebuilt it to bone stock specs it would probably last just fine. I used OEM clutch packs in mine and they grab well. We'll see how it holds up after the hot pump goes in, but I don't expect a problem. The E4OD uses the same basic setup as the C6 for 1st, 2nd, and 3rd gear other than different ratios.
Major difference being the smoother shift feel of the E4OD, while the C6 is meant to be crisp from factory. Get the E4 to shift like that on a new set of clutches and it should last another 200 000 no problem.
Old Dec 29, 2009 | 04:50 PM
George D.'s Avatar
George D.
Didn't you get most of thouse upgrades from that transgo shift kit you got. did you need any special tools when you rebuilt it?
Old Dec 29, 2009 | 07:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
George, didn't you just go through this a while back?
Or was that the engine?
CRS is acting up again.
Old Dec 29, 2009 | 08:00 PM
George D.'s Avatar
George D.
I just replaced the 7.3 with a 6.9 about 6 months ago and now the trany is junk, I guess I have to stick to my motto rather push a ford than drive a chevy.
Old Dec 29, 2009 | 09:14 PM
Dave Sponaugle
You get an atta boy George from me.
Old Dec 29, 2009 | 10:29 PM
rupejosh's Avatar
rupejosh
i think that quote is in the bible or something.
Old Dec 30, 2009 | 05:46 AM
David85's Avatar
David85
I got some upgrades for the pump and valve body in the shift kit, but not anything else like the newer seal or other hard parts.
Yes there are special tools, but I made my own since we have a metal fab shop at home. If you can cut, drill, and wield metal, you can make them up fom scratch.
Basically just some fancy clamps that help hold some of the springs in place while you assemble it.
A transmission stand is handy but expensive. I modified an engine stand instead. Some guys simply use a garbage can to hold it up strait. Worst case senario, you can have it on its side on a bench and roll it over to get to everything. Not ideal, but possible. Make sure the bench and outside of the tranny are VERY clean.
One of the hardest parts is having enough clean working area. You are going to need about twice as much room as for an engine overhaul. Be sure to get the proper manuals if you do this. Its not worth the headache of having to pull it again if something is installed wrong, and its still way cheaper than paying some one else to do it.
These are the manuals I got:
Rebuild book;
E4OD ATSG Transmission Repair Rebuild Service Manual:eBay Motors (item 360191163713 end time Jan-18-10 04:58:19 PST)
Update book;
E4OD ATSG Transmission Rebuild & Update Service Manual:eBay Motors (item 360189898851 end time Jan-13-10 19:23:32 PST)
Special tool;
FORD E4OD CENTER SUPPORT SPRING COMPRESSOR TOOL:eBay Motors (item 130355511121 end time Jan-03-10 21:07:04 PST)
Shift kit;
E4OD 4R100 Transgo Shift Kit:eBay Motors (item 180434766367 end time Jan-18-10 09:31:36 PST)
All of those prices are higher than I paid so shop around before getting anything.
The "special tool" is easy to make or improvise if you have to but I put it there so you can have an idea on how it works.
The following is a tips "ebook" that I found. Its NOT enought to rebuild the transmission, but does give you some good, and free info on updates and also gives a general idea of what is inside and what you are up against.
Download E4OD Free Tips ebook, E4OD Free Tips ebook 1.04 Download
Old Dec 30, 2009 | 12:07 PM
George D.'s Avatar
George D.
well I just got back from talking to the techs at the trans shop and once they found out that I hadn't changed the fluid they said the lugs on the clutches probly sheered and that mechanicly besides that the trans is probly in good shape.
Old Dec 30, 2009 | 01:18 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
with the E40D,
it appears if you keep the fluid changed every 50k(when used for working),install an external filter,cooler,and shift kit,and do not reverse a heavy load as soon as your at your destination (give it just a couple mins at idle to cool down first,as the fluid does not flow through the cooler in reverse.or pay attention to your trans temp gauge first-this is mostly important when backing a trailer,where your may be in reverse for a little bit.if your trans is already quite warm at this point,overheated trans fluid,and damage can be the result.) your going to have the trans for many,many miles/years.
sorry you had to learn the hard way.but keeping fresh clean filtered trans fluid is a must.changed often (every 50k) in a work rig,may not be real cheap insurance,but worth it nonetheless.
i think the E40D gets a lot of its bad rep from people who work them hard without the few aftermarket upgrades to help keep her cool, and poor maintenance.
its based off the C6.so iv got no worries about this trans personally.
proper maintenance is key.
Old Dec 30, 2009 | 02:01 PM
George D.'s Avatar
George D.
Um I guess I should have explained it better they had thought I did the typicle my trans is acting fun lets change the fluid because my trans fluid was so clean and didn't smell burnt. I think my trans did have a good long life at 220k
Old Dec 30, 2009 | 02:44 PM
David85's Avatar
David85
Originally Posted by FORDF250HDXLT
with the E40D,
While I agree backing a heavy trailer up an incline can be damaging, I don't understand the idea that cooler flow stops in reverse. I heard that from a few sources, but looking inside one, the pump is driven off the torque converter, and that spins with the engine.
The weakness of the E4OD is that reverse is too tall. That causes the converter to slip too much and work too hard when moving heavy loads in reverse. That is what generates the heat. The solution is to use 4.10 gears for towing or shift into low range for those that have 4wd.
George, the clutches in the E4OD have no lugs on the clutches. The friction material is bonded on, and the inner or outer ring (depending on what clutch pack you are dealing with) of each clutch disk has teeth on it to grap the drum or outer case and produce the correct gear. If thats what they told, you, be careful because it sounds like a story to me.
Old Dec 30, 2009 | 02:53 PM
George D.'s Avatar
George D.
They were talking about the teath that go to the drum, I know the foward drum on these things have a tendency to brake causing the same problem I have.
Old Dec 30, 2009 | 03:28 PM
David85's Avatar
David85
Ok, sounds like they know what they are talking about then.
Old Dec 30, 2009 | 03:42 PM
George D.'s Avatar
George D.
FOR SALE E-4OD TRANS You think its worth a shot?
