Instument Cluster
Old Dec 29, 2009 | 07:46 AM
haliaeetus70's Avatar
haliaeetus70
Instument Cluster
The owner before me spilled coffee on the intrument cluster and it ran through the holes for the trip resets, so there is old coffee on the inside of the guages and plastic, looks like ****. Does anyone know how or if I can take it out and clean it??? A new instrument cluster from ford is $422!!!! WTF, going to have to try and clean it. Thanx!
Old Dec 29, 2009 | 08:05 AM
pc_2000's Avatar
pc_2000
You should be able to remove the cluster. Once removed, there are screws that hold the clear plastic on. Removing that will allow access to the inside of the plastic and the gauge faces. Hope this helps.
REmoving the cluster will involve removing the plastic trim pieces around it, especially below it. A Haynes manual is pretty good at explaining the removal process.
Old Dec 29, 2009 | 11:55 AM
rainbowATF's Avatar
rainbowATF
These clusters are always on Ebay. I bought several and mixed matched parts. Prices ranged from $20-50.
Old Dec 29, 2009 | 12:09 PM
Conanski's Avatar
Conanski
You don't even need to remove the cluster from the vehicle to clean it, remove the trim around the cluster and then the clear plastic lense and you have access to everything. The gauges also unplug from the cluster body.
Old Dec 30, 2009 | 06:01 AM
TexasGuy001's Avatar
TexasGuy001
If the lense is that bad you can get a new one from NPD or LMC. Don't use Windex to clean it. I would only use a damp cloth.
Old Dec 30, 2009 | 08:25 AM
mrbubble's Avatar
mrbubble
Try using some Plastx if a damp cloth doesn't get the job done. It worked well to remove some of the yellow faded color from my motorcycle's plastic windshield.
Buyerz
Mar 2, 2014 02:35 PM
hardknox
Sep 25, 2010 10:34 AM
plymouthhater
Aerostar
Sep 25, 2005 11:23 AM
Cliff S
1983 - 2012 Ranger & B-Series
Dec 22, 2003 07:44 PM
Cliff S
Dec 19, 2003 08:29 AM
