Tachometer problem
Old Dec 28, 2009 | 10:57 PM
ClaytonSmith's Avatar
ClaytonSmith
Tachometer problem
I have 1992 F250 7.3L Diesel with a 5 speed manual. My tachometer acts weak. The needle moves up when I accelerate, but not far enough. The needle never shows over 1000 rpm at driving speeds when it should actually be at 2000 or more. Anyone know what my problem is?
Old Dec 28, 2009 | 11:06 PM
Hitokori's Avatar
Hitokori
its lazy lol
but seriously it could be that the needle is dragging in the bezel or its not got enough lube in the rotating part
what ever it is its bound to be in the gauge its self
if it was the magnetic pickup or the reluctor ring it would bounce or not work at all
Old Dec 28, 2009 | 11:12 PM
ClaytonSmith
Should I just replace the gauge?
Old Dec 28, 2009 | 11:15 PM
Hitokori's Avatar
Hitokori
.... probably
Old Dec 29, 2009 | 07:22 AM
TexasGuy001's Avatar
TexasGuy001
I think there is a tech article somewhere on here about tachometer repair.
Old Dec 29, 2009 | 08:30 AM
ClaytonSmith
I didn't see an article in the tech section for our generation of trucks; do you know where I can find it?
Old Dec 29, 2009 | 03:00 PM
Eddiec1564's Avatar
Eddiec1564
Best to check the tach sending unit as you have a Diesel truck, that may be your problem.
Old Dec 29, 2009 | 06:47 PM
Linemo's Avatar
Linemo
take a look at your camshaft position sensor this does several things including creating a signal for the tach since a diesel has no ignition system
Old Dec 30, 2009 | 05:16 AM
TexasGuy001
Sorry, but I can't find the article or thread. I know it was on here. It talked about how to clean it and repair it. Maybe it was in the Bronco section or Ranger section.
Old Dec 30, 2009 | 05:31 AM
jr32560's Avatar
jr32560
if you find it see if it can be stickied on the thread -would be a great addition to the other tech subjects
1986F150six
Aug 22, 2016 08:43 AM
AKHunter93
Jun 6, 2016 10:31 PM
Logger1
Feb 26, 2016 08:40 AM
Kopro
Aug 15, 2015 12:58 PM
Toplait
Jun 8, 2012 08:36 PM
