Leaking Cab
Old Dec 29, 2009 | 09:00 AM
DRRXR's Avatar
DRRXR
Thanks Rick
Rick
I appreciate the pic and instructions. Could not rep you.
I think I will make one out of a hand scrapper. Cut a Vee Knotch on the end on only one side.
Thanks again
Rocky
Old Dec 29, 2009 | 09:15 AM
Talyn's Avatar
Talyn
I would make it like the tool, not just one side, cause you'll need to bend it like illustrated, and use it from both sides, sometimes the clips are stubborn.
Old Dec 29, 2009 | 09:27 AM
DRRXR's Avatar
DRRXR
Not sure why it would need two sides when only one is catching the clip.
Old Dec 29, 2009 | 09:34 AM
Talyn's Avatar
Talyn
cause you can only go at it from one direction.
If you use a putty knife, you'll have to bend it so you don't damage the trim when you insert it under the trim.
If you look at Rick's tool, its bent just after the handle.
Remember, you don't put it in and pry up. So, being able to go from both sides with the tool will be beneficial. like i said, some are stubborn and need to be influenced from the otherside.
Plus if you dont have the bend in the tool, you put pressure on the trim while trying to pop it, and you dont want that.
Old Dec 29, 2009 | 10:04 AM
DRRXR's Avatar
DRRXR
No I dont want to screw up the trim. I was going to put the bend in the putty knife. I said scrapper eariler but meant putty knife.
When I get it off and see what the issue is I will fix any rusting myself and then get a shop to install a new window. I could let the shop do the whole thing but I dont trust any glass shops to properly address rust. Been there before with a paint shop on my 91 F-150 with rusting running boards that were externally dressed but no inside rust was treated. So you know what happened in a couple of yrs.
I will post what I find.
Old Dec 29, 2009 | 10:45 AM
Talyn's Avatar
Talyn
Good luck.
Jrgunn5150
Oct 16, 2015 09:42 AM
jetdoc
May 22, 2015 05:45 PM
gavin226
Apr 11, 2015 01:44 PM
Lost Yankee
Dec 1, 2014 12:41 AM
78 & 87 Super Cab
Aug 2, 2013 10:08 PM
