Leaking windshield question
Old Nov 26, 2014 | 08:02 AM
Lost Yankee's Avatar
Lost Yankee
Does the w/s that runs from the bottom of the windshield and ends at the rear of the passenger door frame come as part of the windshield? If not what is the name of it and where can I get one, I think this is part of my leak issue. Thanks guys.
Old Nov 26, 2014 | 10:50 AM
Apocalypse's Avatar
Apocalypse
I cannot for the life of me picture the part you're talking about... can you post a pic up of the area you're talking about?
Old Nov 26, 2014 | 11:38 AM
Lost Yankee
Old Nov 26, 2014 | 11:39 AM
Lost Yankee
Sorry for bad description, hope this helps
Old Nov 26, 2014 | 03:56 PM
Apocalypse's Avatar
Apocalypse
Ok, that's not that big of a deal. Not part of the windshield, but it is replaced when the windshield is replaced. If it's for sure your trouble spot go to any good windshield repair shop and have them replace it. It's not a huge deal but it might be easier to just have them pull the windshield and replace all of the stripping.
Old Nov 30, 2014 | 10:50 PM
greg807's Avatar
greg807
I would make sure to completely inspect the windshield frame if you are experiencing a leak. Had an air leak making noise on a newly purchased 2002 with low miles, the dealer had his local windshield repair shop seal the leak. Within a month I had another leak, so decided to have the windshield pulled and discovered leak was a result of rust caused by improper windshield replacement in the past. I was told of two possible causes, the paint was scratched through with the removal tool or that the prior shop had used improper sealant such as silicone that was corrosive. I do not believe that silicone without scratch through the paint could cause the corrosion. I believe it was a few contributing factors, one of which was improper seal causing water to be trapped between the windshield gasket and the bead of sealant.
Old Dec 1, 2014 | 12:41 AM
warrens73's Avatar
warrens73
^^What he said^^. I just when through this myself. It didn't look like much but there was a few pin hole that let in ALOT of water. Excursions and Super-Dutys are pretty famous for rust along the upper windshield frame.
sixtyfive_ford
1947 and Older Ford Trucks
May 7, 2021 02:39 PM
BeholdenZippy
Feb 24, 2020 07:26 AM
paker
1997 - 2003 F150
May 21, 2019 01:43 PM
niko20
Jan 18, 2019 03:55 PM
F350-6
Aug 26, 2008 08:03 PM
