i need some help please!!!!!!
Dec 28, 2009 | 09:14 PM
won't be bad if it's just your ipr
Dec 28, 2009 | 10:04 PM
how much does a ipr go for. what would make the #5 injector cause to miss??
Dec 29, 2009 | 07:04 AM
if number 5 has a miss it could be a bad injector or it's the low oil pressure
Dec 29, 2009 | 07:38 AM
he tested all the injectors electrically and they passed but the wave when it was fireing showed #5 missing... now does the HPOP run the injectors cause he told me that that is what probly took out injector number 5??
Dec 29, 2009 | 08:43 AM
that is correct however yor problem could be a seal on your injector leaking kepping your oil pressure low,
Dec 29, 2009 | 09:06 AM
so would a bad injector cause it to lose that much pressure and cause my truck to run like crap?????? and make it shut down????? i am new to this and i really apreciate your advise!!!!
Dec 29, 2009 | 09:14 AM
yes if it has a leak I've seen them with leaks that won't allow the truck to start at all,
Dec 29, 2009 | 09:46 PM
just off the top of my head could it be a coolent or glow plug issue also for fordtech 08
or anybody else who knows i am getting ready to buy new injectors and was told there may be 2 lenghts is that true
Dec 29, 2009 | 10:29 PM
there are two lengths of glow plugs the injectors are all the same but the hold downs for injectors are different later on
a glow plug issue would be hard to start cold not warm
and unless your head gasket is leaking causing the miss I doubt it also it wouldn't cause your low oil pressure
Dec 30, 2009 | 01:38 PM
so i got another question if the battery are not the right battery or they are cheap battery would that cause a problem????
Dec 30, 2009 | 05:42 PM
not unless you were getting less than 12 volts
Dec 30, 2009 | 06:10 PM
Quote:
Originally Posted by
reelcrazy
it would cause it to turn over slowly if the cca are not enough however short term they are fine as long as the engine spins fast enough
Dec 31, 2009 | 12:37 PM
well its my HPOP and my IPR so the total damage is 1750 not to bad and that included 2 new ford batterys
Dec 31, 2009 | 12:44 PM
you can't go wrong with ford batteries
Dec 31, 2009 | 12:49 PM
glad you got it fixed! I think just following the thread is some good info.
