Sponsored by: Real Truck
i need some help please!!!!!!
Old Dec 28, 2009 | 05:20 PM
  #31
ayden2004's Avatar
ayden2004
Originally Posted by fordtech08
the complaint is a no start after it's warm not a noise when turning a key
yes but if you scroll up you will see that he also asked about a burping noise under the air filter that is what I was responding to.
Old Dec 28, 2009 | 07:01 PM
  #32
reelcrazy's Avatar
reelcrazy
so my buddy came over from ford and hooked there computer up and said my icp is reading low like 350psi and that injector #5 in missing... so i am replacing the hpop and suggestion on any this else i should have replaced?????
Old Dec 28, 2009 | 07:14 PM
  #33
senix's Avatar
senix
I would say stop there, run the motor, check for any additional codes.
Old Dec 28, 2009 | 07:41 PM
  #34
reelcrazy's Avatar
reelcrazy
dont they have to put everything back together to do that?????
Old Dec 28, 2009 | 07:45 PM
  #35
bayou barataria's Avatar
bayou barataria
My '05 6.0 did exactly the same thing when it blew the hpop seal, it is supposed to have very high pressure I don't remember exactly whet it was, something crazy like 800 or 2200 psi.. It was just the seal not the pump.
Old Dec 28, 2009 | 07:48 PM
  #36
senix's Avatar
senix
But of course, put it back together, see how it runs, check for codes and go from there.
Old Dec 28, 2009 | 08:05 PM
  #37
reelcrazy's Avatar
reelcrazy
man i hope it is just the seal if you dont mind me ask how much did that run you
Old Dec 28, 2009 | 08:08 PM
  #38
bayou barataria
It was under warranty, I don't remember and I have no clue what it takes to replace it I think it is accessable from the top of the engine. I sure it is quite expensive at the dealer.
Old Dec 28, 2009 | 08:12 PM
  #39
reelcrazy's Avatar
reelcrazy
well it is a 16 hour job thats what the book says but my buddy is going to do it on the side for 700 in labor and what ever the parts cost.... that probly why i am asking should i replace anything else back there since its opened up already????
Old Dec 28, 2009 | 08:15 PM
  #40
senix's Avatar
senix
I would work on the parts in question but do check other items as needed. You never know something may come up as you start taking things apart.
Old Dec 28, 2009 | 08:16 PM
  #41
fordtech08's Avatar
fordtech08
do you have an icp sensor on your front passenger valve cover?
Old Dec 28, 2009 | 08:26 PM
  #42
fordtech08's Avatar
fordtech08
you might want to replace the ipr valve first, it's cheaper then a pump and easier to get to (kind of)
Old Dec 28, 2009 | 08:48 PM
  #43
reelcrazy's Avatar
reelcrazy
i believe it is in the rear of the motor!!!!
Old Dec 28, 2009 | 08:57 PM
  #44
fordtech08's Avatar
fordtech08
ok so you have the early build that changes everything definetly ask him to pull the ipr first
Old Dec 28, 2009 | 09:10 PM
  #45
reelcrazy's Avatar
reelcrazy
will do he his starting tomorrow man this is going to hurt the pocket bad.....
