Sponsored by: Real Truck
windshield Wiper Motor
Old Dec 26, 2009 | 05:59 PM
Redsparky's Avatar
Redsparky
I have a 2002 F-250 Super Duty my wipers quit working, i replaced the wiper motor and the multi-function switch but they still won't work. If any one has some advice it would really be nice.
Old Dec 26, 2009 | 06:30 PM
fordtech08's Avatar
fordtech08
did you check fuses 54 and 33 under the dash other then that assuming new parts you have a wire issue
Old Dec 26, 2009 | 08:46 PM
Redsparky's Avatar
Redsparky
Yes, someone mentioned a wiper control module or the gem module but not for sure.
Old Dec 26, 2009 | 08:56 PM
fordtech08's Avatar
fordtech08
no not on this one, this should help and don't guess your new stuff is good
PINPOINT TEST A: THE WINDSHIELD WIPERS ARE INOPERATIVE
CONDITIONS DETAILS/RESULTS/ACTIONS
A1 CHECK CIRCUITS 65 (DG) AND 1002 (BK/PK) FOR VOLTAGE
Windshield Wiper Motor C125
Measure the voltage between windshield wiper C125 pin 5, circuit 65 (DG), harness side and ground; and between windshield wiper motor C125 pin 8, circuit 1002 (BK/PK), harness side and ground.
Are the voltages greater than 10 volts?
Yes
GO to A2.
No
REPAIR the circuit(s) in question. TEST the system for normal operation.
A2 CHECK CIRCUITS 57 (BK) AND 676 (PK/OG) FOR OPENS
Measure the resistance between windshield wiper C125 pin 6, circuit 57 (BK), harness side and ground; and between windshield wiper motor C125 pin 3, circuit 676 (PK/OG), harness side and ground.
Are the resistances less than 5 ohms?
Yes
GO to A3.
No
A3 CHECK THE MULTIFUNCTION SWITCH
Multifunction Switch C202b
Carry out the multifunction switch component test.
Refer to Wiring Diagrams Cell 149 for component testing.
Did the multifunction switch pass the component test?
Yes
GO to A4.
No
INSTALL a new multifunction switch. REFER to Section 211-05.
A4 CHECK CIRCUIT 57 (BK) FOR OPEN
Measure the resistance between C202b pin 6, circuit 57 (BK), harness side and ground.
Is the resistance less than 5 ohms?
Yes
GO to A5.
No
REPAIR the circuit. TEST the system for normal operation.
A5 CHECK CIRCUITS 56 (DB/OG), 58 (WH), 61 (YE/RD), AND 63 (RD) FOR OPENS
Using the following table, measure the resistance between the multifunction switch C202b harness side and the windshield wiper motor C125 harness side:
Multifunction Switch C202b Windshield Wiper Motor C125
pin 2, circuit 56 (DB/OG) pin 10, circuit 56 (DB/OG)
pin 3, circuit 58 (WH) pin 11, circuit 58 (WH)
pin 4, circuit 61 (YE/RD) pin 1, circuit 61 (YE/RD)
pin 1, circuit 63 (RD) pin 9, circuit 63 (RD)
Yes
GO to A6.
No
A6 CHECK FOR CORRECT WIPER MOTOR OPERATION
Disconnect all wiper motor connectors.
Check for:
corrosion
pushed-out pins
Connect all wiper motor connectors and make sure they seat correctly.
Operate the system and verify the concern is still present.
Is the concern still present?
Yes
GO to A7.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation.
A7 CHECK THE WINDSHIELD WIPER MOTOR
Carry out the windshield wiper motor component test as outlined in this section.
Did the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. Concern may have been caused by incorrect binding pivot arm adjustment. REFER to Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
INSTALL a new windshield wiper motor. REFER to Windshield Wiper Motor in this section.
Old Dec 27, 2009 | 12:57 PM
Furian's Avatar
Furian
You Keep What You Kill
Excellent Dan!
Old Dec 27, 2009 | 06:01 PM
Redsparky's Avatar
Redsparky
Owners manual does not show a fuse 54 they show a fuse 106 which is a main fuse but when i pulled it my abs light syays on.
Old Dec 27, 2009 | 06:11 PM
fordtech08's Avatar
fordtech08
per wiring diagram it's those two fuses
Jesser02EX
Mar 4, 2014 06:31 PM
GTBksRule
Electrical Systems/Wiring
Feb 9, 2013 08:16 AM
dcicc50
Feb 6, 2009 04:34 PM
whyjay
Dec 8, 2008 06:29 AM
thullz
Jun 8, 2006 10:37 AM
