Wipers only work on high
Old Dec 5, 2008 | 05:36 AM
whyjay's Avatar
whyjay
I replaced the switch yesterday & the wipers are still doing the same thing. Is there a relay I can replace or do I have to replace the wiper motor?
Old Dec 5, 2008 | 08:16 AM
TexasGuy001's Avatar
TexasGuy001
Yes there is a relay. It is somewhere on the passenger side of the dash behind the glove box. At least that is where it is on 92-96.
Old Dec 5, 2008 | 08:19 AM
whyjay's Avatar
whyjay
any idea of a price? $$$
Old Dec 5, 2008 | 09:41 AM
quicklook2's Avatar
quicklook2
not much.
or go to junkyard.
it is behind glovebox, open it all the way and listen for it.
Old Dec 5, 2008 | 10:10 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
'87's likely the intermittent wiper governor.
It plugs between the switch and the harness.
These are a PITA to access, but they are up inside the dash above the fuse panel.
Some people have had luck re soldering the connections inside, but I didn't.
Search "wiper governor" and you'll come across many hits with this same symptom.
Good luck!
Old Dec 5, 2008 | 10:17 AM
whyjay's Avatar
whyjay
My truck is a 89. I'm going to check today after work.
Old Dec 5, 2008 | 10:22 AM
whyjay's Avatar
whyjay
I do remember seein what looked like a plug between the switch plug & the harness plug. Would that be it?
Old Dec 5, 2008 | 10:25 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Your profile says '87.....
Yes, that's it!
Old Dec 5, 2008 | 10:32 AM
whyjay's Avatar
whyjay
Ok I think i've got my profile fixed now. When I get off work here in about an hour I'll fix my wipers. thanks for everyones help.
Old Dec 5, 2008 | 10:43 AM
quicklook2's Avatar
quicklook2
this is why it would be helpful to put your year in the post.
Old Dec 6, 2008 | 11:12 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Just an FYI for anyone who may stumble on this thread.
I happened to find the box:
ONE
SW-2259
E9TZ-17C476-A
Governor Asy
So, there you go, the part number for these '87 era trucks.
Old Dec 6, 2008 | 11:15 AM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Don't this same problem for 79 F150?
if try in med speed it shut down motor and wiper would be stay up until I turn off it go back to bottom of window if I use High speed it work fine but try med or low nothing happened.
Old Dec 8, 2008 | 06:14 AM
whyjay's Avatar
whyjay
Ok so I got off friday & tore into it. The box is called a governor switch. The local store don't have them the the dealership wants $135. I can't see paying that since I rarely drive my truck. I wonder if it will pass inspection if the wipers only work on high?
Old Dec 8, 2008 | 06:26 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't know a thing about inspection in VA.
As I said above you can open it up and re-solder the connections inside.(no guarantee on how long that will last)
OR, you can go to the autoparts and get a 2 speed control switch, put that in your dash and connect it directly to the harness leaving out the governor.
Old Dec 8, 2008 | 06:29 AM
whyjay's Avatar
whyjay
That's not a bad idea. Thanks ArdWrknTrk
OlBrownTruck
Apr 27, 2017 04:02 PM
Chewy996
2009 - 2014 F150
Apr 21, 2017 08:13 AM
pcartwright
Aug 31, 2016 10:12 AM
dledm
Bronco II
May 25, 2016 08:27 PM
ArlyDude
Dec 14, 2014 09:32 PM
