carbs
Old Mar 23, 2000 | 09:34 PM
390GT's Avatar
390GT
carbs
does anyone know what the 406tripower ran for carbs?...i kinda want to know
Old Mar 23, 2000 | 11:12 PM
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
carbs
I believe they were motorcraft 2barrels, if I remember right they were special, tri-power, cabs. I know two of them, the front and rear I think, were different than the middle one. because those two didn't have a choke on them, I don't think they had Idle adjustments either. this is because, in normal driving the engine would run off the middle one only, the other two opened up only when the throttle was stomped. Like secondaries in a 4v carb.
John
Jefferson City, MO
1976 F150 Ranger XLT, 390ci--redneckmobile
FORDTRUCKMAN1976
carbs
I believe they were motorcraft 2barrels, if I remember right they were special, tri-power, carbs. I know two of them, the front and rear I think, were different than the middle one. because those two didn't have a choke on them, I don't think they had Idle adjustments either. this is because, in normal driving the engine would run off the middle one only, the other two opened up only when the throttle was stomped. Like secondaries in a 4v carb.
John
Jefferson City, MO
Old Mar 23, 2000 | 11:27 PM
390GT's Avatar
390GT
carbs
i know how they operated...running off the center...and being mechanically actuated to open the other 2 carbs..but....i need some carbs for my intake
Old Mar 24, 2000 | 12:06 AM
mk's Avatar
mk
carbs
Got a great little book here, called 'Ford High Performance Parts Identifier'. It says the carbs were all Holley 2bbls and even gives the original part numbers. Are you setting up a tri-power on your 390? The carbs were a 2300-C series.
Old Mar 24, 2000 | 07:03 PM
390GT's Avatar
390GT
carbs
yes the 390 is gonna be a sixpack.
thanx... for the info
Old Mar 24, 2000 | 07:16 PM
78f100_1's Avatar
78f100_1
carbs
special blue
1978 - 1996 Big Bronco
Jan 15, 2013 11:17 AM
mdr617
Mar 13, 2011 03:48 PM
old_man_winter
Sep 21, 2006 04:35 PM
roger dowty
Alternative Fuels, Hybrids & Mileage
Oct 8, 2005 02:02 AM
jeepin
Aug 12, 2003 02:22 PM
