Truck was running fine went into the store, came out to start it and the fuel pump wouldn't kick on.
I have replaced the relays and fuses along with the pump and filter.
I have read some articles about loose connections in the power distribution box, any ideas?
Thanks
Reason: I also have checked the inertia switch :/
Put a hand on both the fuel pump relay and the power relay.
Have someone turn on the key.
Do both relays click when the key is turned on and one second later does the fuel pump relay click again?
Let us know so we know where to have you look next.
Okay so I checked to see if the relays clicked and they didn't.
Neither one, I also pulled the fuel pump relay fuse and checked it. It was fine.
Thanks for the help.
