what hussler said, they are connected in parallel and thus retaining the same voltage but doubling the amp hours (assuming they are the same amp hours). however it seems most of the connections are run off of the pass side battery and therefore making that batt the 'main' one. however, these connections could be transferred to the drivers side battery.
You should all was use jumper cables,and run big draw accessories off the passenger side battery.because the (main battery) is the passenger side.the flow of current flow on theses starts at the pass. side.the driver side gives the battery more run time. the charging system has to go though the right side batt to get to the left side.witch is more wire more resistance
Just a quick question on that. It should not mater which one you hook the cables to . since the resistance in going to be the same. since both batteries will drian at the same rate so the current has to flow through the longer wire either way.? right?
The owner's manual states that you should always hook jumper cables to the passenger-side battery. I presume, though, that that's a shorter path to the starter, which isn't really relevant with a trickle charger. I _have_ heard that, generally, it's not good to charge batteries in parallel, but a slow trickle charge may be okay. 'Course, the alternator is charging the two in parallel all the live-long day.
I have an "On Board" trickle charger and it it permanently connected to the drivers' side battery. Has been for over a year and keeps both batteries topped off. No problems.
well when i had my truck the passenger side batter was a little stronger and when just the driver side was hooked up it would just click, being only 12.3 volts and the other battery was 13.6 volts. if i used the other side, jsut that battery alone would start the truck, so even thoe the other batter was only a little weaker it would only click.
^^^^^ That's a perfect example of the weaker battery "taking down" the stronger one. And it's a good illustration of why you should always maintain them in pairs.
