hpx line
Old Dec 24, 2009 | 03:58 PM
arkredneck's Avatar
arkredneck
hpx line
just got the itp hpx line and about to install it ill let yall know if i notice anything different i am thinking a adrealine hpop is gonna be coming soon to and maybe just maybe a d66
Old Dec 24, 2009 | 05:16 PM
arkredneck's Avatar
arkredneck
i put the hpx line on and it seemed to quite the idle and it seemed to run smoother but i don't know maybe its just me wanting a difference since i did something to the truck
Old Dec 24, 2009 | 05:46 PM
rideracelivemx7's Avatar
rideracelivemx7
well if your going to do the adrenaline HPOP just return the HPX line because the adrenaline hpop evens out the pressures so it renders the hpx line useless, or just looks cool. d66! hah i did the hpx line and it really didnt do toooo much for my truck, smoother idol when cold and was sometimes lopey when hot but my injector seals were terrible, so im sure that has alot to do with it. but congrats onthe HPX linem who did you buy it from?
Old Dec 24, 2009 | 05:52 PM
arkredneck's Avatar
arkredneck
itp diesel
Old Dec 24, 2009 | 07:41 PM
Iallwork's Avatar
Iallwork
What's a hpx line?
Old Dec 24, 2009 | 07:51 PM
arkredneck's Avatar
arkredneck
it's a line that connects the right and left cylinder bank high pressure oil galleys. it's suppose to even out the pressures and make the truck run smoother
Old Dec 24, 2009 | 08:07 PM
Iallwork's Avatar
Iallwork
Thanks for the explaining.
Old Dec 24, 2009 | 08:36 PM
oldbird1965's Avatar
oldbird1965
x2 on not needing it with the adrenaline. I was told to take it off when I installed the adrenaline.
Old Dec 24, 2009 | 09:36 PM
rideracelivemx7
HPX stands for high pressure cross over line, just incase you wanted to know. i got my HPX from riffraff, price was unbeatable.
Old Dec 25, 2009 | 08:08 AM
MADVAN's Avatar
MADVAN
If you have the oem check valves use the line.
If you removed the check valves no line is needed.
The check valves are in the pumps outlet line fittings.
Bill
Old Dec 25, 2009 | 02:38 PM
arkredneck's Avatar
arkredneck
but would the line matter either way it couldn't hurt right?
Old Dec 25, 2009 | 02:49 PM
rideracelivemx7
it will not hurt anything unless your an unlucky son of a gun and pops a hole in the line and blows 2 gallons of oil in your engine bay, other than that, no theres no way this will hurt your truck, it will be the same or will idle smoother
Old Dec 25, 2009 | 03:13 PM
arkredneck's Avatar
arkredneck
yeah that would for sure make a really bad day
Old Dec 25, 2009 | 08:12 PM
oldbird1965
If you decide to get one, get the steel one. I had a flex rubber line and from the heat of the motor it developed a leak. I had 500 miles to go and had another one on order. I evisioned what riderace said all the way and watched my oil pressure gauge constantly.
Old Dec 25, 2009 | 08:53 PM
arkredneck's Avatar
arkredneck
i did get the steel one but the gap between it and the turbo looks awfully close probably gonna fine something to wrap around it just in case
