Blowing 40 amp main fuse
Old 05-20-2009, 03:23 PM
rlay302's Avatar
rlay302
rlay302 is offline
I currently have a 2001 F-150, that blows number 113 fuse (which is a 40 amp fuse) in the power distrubution panel under the hood.
This fuse is identified as "Ignition switch battery feed - run and accessory circuits."
No other fusues blow.
Old 05-20-2009, 07:34 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
In which key switch position does it blow, RUN or ACCY?
Old 05-22-2009, 07:51 AM
rlay302's Avatar
rlay302
rlay302 is offline
Problem Solved
We found it, the wires harness near the brake pedal arm had a bare spot and was making contact. Which was blowing the fuse.
tvliftcabinet
02-26-2017 05:06 PM
superdutyf450
10-12-2015 05:41 PM
andrew034
29
08-18-2012 03:09 PM
secakc
01-29-2011 04:53 PM
19buzzard67
01-29-2006 04:56 AM
Quick Reply: Blowing 40 amp main fuse
