Romp Romp Romp
Old Dec 24, 2009 | 12:23 PM
74baja's Avatar
74baja
Romp Romp Romp
Hi all,
I have Rotella T conventional oil in my truck now. If I don't plug in in weather around 20* or below, the truck will start easily, but often romps hard for about 10 seconds, and then either dies or smooths out. If it dies, it can be restarted easily, romps a little, the runs. Also, a reasonable amount of white/gray smoke when this happens. Is this just normal romping for conventional oil? I plugged in more often last year (before I saw Lostcausses's pictures *shudder*), so I don't know.
Thanks
Old Dec 24, 2009 | 12:42 PM
BillyBob69's Avatar
BillyBob69
From everything I have heard...switch to Synthetic. The romps will be gone.
Old Dec 24, 2009 | 12:52 PM
Ponyboychris's Avatar
Ponyboychris
^^^ What he said^^^ My romps are long gone now with 5w-40 Synth RotellaT.
Old Dec 24, 2009 | 12:53 PM
PaysonPSD's Avatar
PaysonPSD
X2 No more romps since switching to Rotella 5w-40 Syn.
Old Dec 24, 2009 | 01:17 PM
big poppa's Avatar
big poppa
X4, do the switch to synthetic and you'll be fine..This is the first year I went with a syn. blend 50%dino 50%synthetic Schaeffers 7000 and I'll get maybe an initial 2 romps buts smooths out fast, thats at about 17* at nite, when the weather is warmer than that, no romps.
Old Dec 24, 2009 | 01:38 PM
74baja's Avatar
74baja
Well, I have to change the oil soon anyway, so I guess I'll hunt around for some cheap synthetic. It just hurts really bad to spend $100+ on an oil change. How many miles do you guys go between changes on synth? And will the 5W40 synth be heavy enough in the summer?
Old Dec 24, 2009 | 01:44 PM
bigsteve1969's Avatar
bigsteve1969
i like the romps myself makes folks look
Old Dec 24, 2009 | 02:06 PM
nlemerise's Avatar
nlemerise
I run 5000 on syn in the winter and 5000 miles on dino in the summer. Yes, the 5W40 syn is fine in the summer...Four gallons of 5/40 Rotella-T syn is just under $80 at Walmart and the Motorcraft filter is $10. My truck starts smoothly in overnight temperatures below zero without the block heater plugged in.
Old Dec 24, 2009 | 02:52 PM
bfife's Avatar
bfife
still plays with trucks
5w40 is fine for all seasons. the "40" is the same for both oils. the "5" just makes things flow alot better when its cold.
I've run the 5w40 syn for over 5 yrs now, towing heavy, hot weather and cold. It works well for me.
Barney
Old Dec 24, 2009 | 02:55 PM
rbaker6336's Avatar
rbaker6336
I run rotella synthetic 10k miles.I could go more but its easy to remember
Old Dec 24, 2009 | 03:43 PM
Izzy351's Avatar
Izzy351
Yep -- I run 7-8k on my syn. I could also go longer. Basically, if you run 10k on it, you're actually saving money over dino at 5k. Of course, a lot of folks argue that they push their dino further than 5k... I just believe in syns -- every fluid in my truck is now synthetic (to include brake fluid).
Old Dec 24, 2009 | 03:52 PM
ron's power stroke's Avatar
ron's power stroke
hmmmm nothing but delo 400 15/40 and my truck doesnt even know what a romp is..not even after the swap to SS injectors...oil test after 12000 miles said lots of molly and miles left..our T444E IH role back romps hard though..we run 15/40 rottela in that
Old Dec 24, 2009 | 04:00 PM
Izzy351's Avatar
Izzy351
I ONLY romped on Delo. To the point where I won't ever run it again. Go figger.
Old Dec 24, 2009 | 04:08 PM
Ford79's Avatar
Ford79
My last oil change was to Schaeffer's 5-40 synthetic. I most likely will not go back to 15-40 and will definately never use Motorcraft 15-40 again. That crap made my truck romp at 50 degrees.
Old Dec 24, 2009 | 04:12 PM
Izzy351's Avatar
Izzy351
That's funny, Mike. When I had the Delo in, I romped at 40. Weird.
