GPCM
Old Dec 25, 2009 | 06:52 AM
Joe28443's Avatar
Joe28443
Joe28443
If I remember I looked at the plugs and they seemed fine. I will pull them off again later and check them out. If you can find those pics that will be great
Old Dec 27, 2009 | 11:03 PM
SkySkiJason's Avatar
SkySkiJason
Pink one is the new one, the blue one was what the 'bad' one looked like. If ya look carefully, maybe you can see where the plastic is melted around the big pin. It was failing to make good contact to the GPCM...
Old Dec 28, 2009 | 06:45 AM
Joe28443's Avatar
Joe28443
Joe28443
Thanks I will get out there today and check it out. Atleast it will crank now though
Old Jan 9, 2010 | 06:16 PM
snapper021's Avatar
snapper021
Glow plug codes
My wifes excursion threw a cel today and after checking it discovered that I had the #2,4,6, and 8 glow plug trouble codes, with the glow plug control module also.
Any ideas? I see the control module is split for each head, i guess one of the connectors to the 2,4,6, and 8 cylinder could be bad and the other good?
Thanks
Old Jan 9, 2010 | 06:57 PM
Joe28443's Avatar
Joe28443
Joe28443
I wish I could help, maybe someone will be along shortly,I am new to the whole diesel world
Old Jan 9, 2010 | 07:45 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Joe28443,
Did you check your UVCH connectors inside the valve covers, that may be the problem. Just a though.
Old Jan 9, 2010 | 08:05 PM
PaysonPSD's Avatar
PaysonPSD
Thanks
Clear the codes and swap the connectors. If you still get the codes for 2,4,6,8 then you need a new GPCM.
9 times out of 10 if the codes are for all one bank it is a GPCM fault.
Old Nov 19, 2010 | 09:05 AM
DeathSpiral's Avatar
DeathSpiral
Replaced GPCM in time for winter...
Replaced my GPCM last weekend and the truck started up like a champ in the cold on the first turn of the key. Had to disconnect the Cold Air Intake to get to the 10 mm nut on the other side.
Bought mine from partsguyed.com. It was cheap and came fast.
Thanks for all the info in the prevous posts.
Later...
- Wayne
Old Nov 19, 2010 | 09:24 AM
driximus's Avatar
driximus
I was looking for a pic of the failed pigtails - none in my photobucket... I'll dig one out tomorow and take one.
Basically, the plastic around the big pins was melted and pins no longer made good contact. It was easy to see the problem when I looked at it. REALLY made me want a simple freakin' GPR. LOL!
I prefer the module. When 1 Glowplug goes out it tells you Hey replace #3 dummy. Then I have to only pull off one cover and test 1 GP and pull and check it rather then all 8.
Originally Posted by willeo6709
excursions and some california emissions 7.3's have a control module with individual output wires to each glow plug. Its supposed to help reduce the cold start emissions apparently, but its a whole boatload more complex than a GPR. Buy the stancor relay on guzzl'es mods page....well worth the cash and an easy install. For the GPCM ther is no cheap easy relacement
Yes but as I said above it makes knowing what GP is out and changing faster.
04badford
Dec 31, 2014 04:54 PM
warren561
Massachusetts Chapter
Nov 25, 2014 04:47 PM
db916gt
16
Mar 12, 2009 11:37 PM
DieselBeast01
31
Jan 9, 2009 09:26 AM
RoadWarriorz
6.4L Power Stroke Diesel
Nov 8, 2007 02:42 PM
