crazy guages
Old Dec 23, 2009 | 01:12 AM
blacksmokesmile's Avatar
blacksmokesmile
crazy guages
OK, I'm thinking I may have a ground issue or somthing. my windshield wipers will stop working, then if I use my right blinker, they start working as soon as I turn it off. my guages start acting up when I use my blinkers or my headlights. any ideas??
Old Dec 23, 2009 | 04:56 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
What year and model but sounds like bad ground or broken supply.
Old Dec 23, 2009 | 09:17 AM
starmilt's Avatar
starmilt
Ground, in the older pickups I would say it was in the dash somewhere but I haven't had that problem with one of these.
Old Dec 24, 2009 | 03:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Could be something as simple as disconnecting the cluster connection and plugging it back in to fix your problem.
Or it may be a broken cab ground out under the hood.
With the years that are on these trucks, adding or updating grounds is not a bad idea.
Old Dec 25, 2009 | 08:24 PM
ford trans tech's Avatar
ford trans tech
ground issue
both negative battery cables are supposed to have pigtails attached to the radiator support and fender
there should also be a ground from the engine to firewall and another from the engine to the frame
rossseger
Nov 3, 2014 02:09 PM
Unrealo4
Jul 22, 2012 08:45 PM
diesel77
Apr 26, 2010 08:06 PM
Aggie05
Bronco II
19
Apr 4, 2006 03:49 PM
mgundry
Electrical Systems/Wiring
May 31, 2004 11:46 AM
