Injector testing
Old Dec 22, 2009 | 08:19 PM
damicofuel's Avatar
damicofuel
Injector testing
is there any way to test an injector? the local shop wants 50 bucks, and being the cheap sob I am I am hesitant, plus they want 209 for a used one!!
Old Dec 22, 2009 | 08:49 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Anybody with an AE that is close to you would be happy to help you out I am sure. What are your symptoms?
IMO - Do not pay that much for a used injector. You can buy a brand new Alliant for less...
Old Dec 23, 2009 | 06:21 AM
damicofuel's Avatar
damicofuel
I tested it with my pro-link, weak buzz on #1, but I can't do a running cylinder cut out test, will the AE do that?
Old Dec 23, 2009 | 07:22 AM
Kwikkordead's Avatar
Kwikkordead
If it will, that would be a good reason to get the software.
Old Dec 23, 2009 | 10:52 AM
Riffraff Diesel
PREMIUM SPONSOR
Here the link to the list of everything it will do for Ford vehicles with the enhanced bundle. Not everything applies to the Powerstroke though.
Ford Engine Module List
Old Dec 23, 2009 | 12:16 PM
damicofuel's Avatar
damicofuel
Thanks Clay, that helped. I will be calling you on some mods soon. If the tax man wasnt taking all my money I would get the HP injector set!!!
Old Dec 23, 2009 | 07:19 PM
F350-6's Avatar
F350-6
No. AE can run a cylinder contribution test and let you monitor % change in rotational velocity (perdel) readings live, as well as run the buzz test. To cut out individual injectors you'll either need to unplug each injector individually, or build a break out box where you can manually switch each injector off.
However, based on buzz tests, rotational velocity and contribution test readings with AE, you can pretty much guess which injector to unplug to confirm your issue.
Old Dec 23, 2009 | 10:48 PM
damicofuel's Avatar
damicofuel
thanks, the pro link will do all that too, but cost a lot more, shoulda checked here before buying pro link cartridge. But anyway, got injector back from shop and there was a plate loose inside causing oil to bypass and not pushing the plunger down. so for about 60 bucks got injector gone over and new o ring set installed. that will keep it going untill gather enough money for big horespower injector replacement. I've got the fever, instaling the Bully Dog tripple tuner GT now.
Old Dec 24, 2009 | 06:20 AM
F350-6's Avatar
F350-6
... shoulda checked here before buying...............................
You really should follow you're own advice and check here first. For about the same money as the Bully pup, you could have got a real tuner with switch on the fly capability that will run circles around that big advertising budget stuff. Clay could hook you up with a real tuner too if there's still time to return that bully pup.
Old Dec 24, 2009 | 10:54 AM
Riffraff Diesel
PREMIUM SPONSOR
The DP Tuner holiday sale is on for one more week. This is the best deal you will see all year on an awesome tuner.
Riffraff Diesel: DP Tuner
therigwelder
Nov 22, 2014 03:14 PM
Eric Kropp
Aug 10, 2014 03:56 PM
blueline970
Oct 3, 2012 09:55 PM
2006powerstroke90
Mar 19, 2012 07:41 PM
neversosure
General Diesel Discussion
48
May 24, 2011 06:29 AM
