Which plug on FICM?
Old Oct 2, 2012 | 11:59 PM
blueline970's Avatar
blueline970
Which plug on FICM?
Ok which plug is it on the ficm that goes to the passenger side injectors and which pin holes are for the number 5 injector? I have a dvm and wondering what test with it can I use to test the wires? I don't see any chafing in the visible spots. I want to make sure I cover my bases before looking to buy a new injector. Can you use a dvm to test the injector by chance?
Old Oct 3, 2012 | 06:12 PM
cheezit's Avatar
cheezit
you will need a wire diagram for pinout on the harness.
yes you can test an ijector. it has 4 wires 2 for open coil, 2 foir close coil. should be 4 ohms or less on either coil and coils sould be open loop to each other.
Old Oct 3, 2012 | 06:27 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is part of your question:
http://www.fordtechservice.dealercon...ficm_guide.pdf
Not sure about which pin goes to where.
Old Oct 3, 2012 | 06:30 PM
amdriven2liv
And a thread with the info you are looking for.
https://www.ford-trucks.com/forums/1...am-pinout.html
Search is your friend.
Old Oct 3, 2012 | 09:55 PM
blueline970
Yeah been searching on my phone and it doesn't work that great. Thanks for info.
speedracer54729
Modular V8 (4.6L, 5.4L)
Aug 11, 2019 07:27 PM
LONCO
Nov 27, 2018 02:34 PM
Eric3131
Dec 3, 2017 10:04 AM
agg_bagg
18
Sep 24, 2015 06:51 PM
jejenkins417
Jul 26, 2011 09:14 PM
