Window binds up
Old Dec 22, 2009 | 09:37 AM
superduty4x4's Avatar
superduty4x4
Window binds up
Since replacing the passenger front door on my truck a few months ago I've had a problem with the window. Before the door replacement it would roll up and down nice and smooth, but since putting the truck back together the window motor really has to labor to move the window up or down. We tried adjusting the track when we were reassembling the door without much success, and I was hoping that things would "wear in" and the window operation would go back to normal but no such luck. Any ideas/suggestions?
Old Dec 22, 2009 | 09:50 AM
CPUNeck's Avatar
CPUNeck
Couple things, did you re lube all the tracks to include spraying the "glass" channels with silicone lube? When you swapped all the parts over, did the old parts "fall" into place in the new door, or did you have to do some coercing? When you installed the motor, did you go back with rivets, or screws? If screws, perhaps the orientation of the motor is all that's in order.
Action4478's Avatar
Action4478
Did you save the motor from the old door ?...Sometimes that happens from lack of use . I have had to lube the rubber tracks before also, sometimes they are just dirty too...
Old Dec 22, 2009 | 11:35 AM
superduty4x4
Everything swapped right over and bolted up just fine. None of the internals of the door were damaged.
Rick, the only part that was changed was the door. The old one was gutted, removed, new door hung and all guts installed.
The track wasn't any dirtier going in than coming out, and no I did not lube it with anything. I guess that will be the next step to see if it helps. When I get time I'm going to look and see if maybe the molding didn't get snapped all the way into the track in one spot or something.
Old Dec 22, 2009 | 12:08 PM
Action4478's Avatar
Action4478
You may want to look to make sure the rubber track is seated in the metal track properly ...
Old Dec 22, 2009 | 02:20 PM
Kwikkordead's Avatar
Kwikkordead
When I bought my truck the driver's window was laboring to roll up.
The only thing that I did, five years ago was to lube the tracks with silicone.
It's been fine ever since.
Old Dec 22, 2009 | 02:58 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Got the same issue I will see if lube will help.
Old Dec 22, 2009 | 03:06 PM
Kwikkordead
I used this stuff and worked it into the groove with a long narrow screwdriver.
Store Locator | NAPA Online
Old Dec 23, 2009 | 11:13 AM
flatbeder's Avatar
flatbeder
got thew same problem on my passenger door. hopefully lube will work?!
Old Dec 23, 2009 | 11:32 AM
PwerStroke99's Avatar
PwerStroke99
Karma is getting u!! If u would stop threatening to sell the rag, it wouldnt act up on you!!! LOL
Old Dec 23, 2009 | 12:50 PM
superduty4x4
Well start letting everyone you know that if they need a real estate agent call my wife and I'll be able to keep the dang thing!
Old Dec 23, 2009 | 01:59 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Silicon spray is the key! I sprayed mine about 2 years ago and they still work like they were brand new. My brothers truck was having the same issue a couple months ago, a little silicon spray and he was in business.
Old Dec 23, 2009 | 02:50 PM
DieselCamper01's Avatar
DieselCamper01
Hope this isn't a stupid question but are all of you talking about lubing the metal track that the roller glides in or the rubber/felt window tracks on the sides?
Old Dec 23, 2009 | 02:59 PM
CPUNeck's Avatar
CPUNeck
I thought the only stupid questions were the ones not asked?
You'll want something a little more substantial for the roller track, like real grease or for me it's like a lithium wax stick. The silicone is for the rubber/felt tracks. Works great, my father-inlaw has been a glass man for ~30 years, I usually get release agent from him for the job (it has a high silicone content), but straight silicone works great too. You'll be amazed how much better it will work.
Old Dec 23, 2009 | 03:05 PM
mndiesel's Avatar
mndiesel
Great thread, just dealt with this at the last GTG and thought my motor was going. Will go get some silcone spray and do the felt. Thanks
Matt Black
Jul 13, 2013 12:25 PM
Bronco_Daddy
Apr 4, 2012 08:46 PM
eriklynden
Jun 17, 2011 10:30 AM
DanielC
Aerostar
Jan 16, 2011 01:51 AM
BroncoBuster
1978 - 1996 Big Bronco
Jun 18, 2005 11:18 PM
